Old 03-31-2007, 11:17 AM   #1
lb23 is on a distinguished road
Distributor swap
My 79 Chevy PU used to have a 350 diesel engine. I replaced it several years ago with a 73 Olds 350. I would like to replace the distributor with a HEI from a newer model. I don't want to use an after market dist.
What will fit the 73 Olds and give me the best mileage/performance?
LB
lb23 is offline   Reply With Quote
Old 03-31-2007, 01:38 PM   #2
436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice
Your best bet as you say is an HEI. It needs to be from an Olds engine though, Although they look in every GM make, they are specific to the engine family. you'll need to find one from a 75-80 olds. any 403, 350, 307, 455. The later model distributors will have computer stuff in them, and no mechanical advance. Not sure if the distributors are the same from a Big block to a small block olds, but I would guess they are. Should be easy to find one in a junkyard. I know of a bunch in the local yards.. EBAY would also be a place to check.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
436'd skylark is online now   Reply With Quote
Old 04-01-2007, 10:03 AM   #3
Thanks Joe, any knowledge of which years/models are more desirable.
Old 04-01-2007, 06:30 PM   #4
Like I said before any HEI that is not computerized. There is no difference in the distributor between the years. There may be some difference in the timing curves, but none are really desireable. I'd rebuild it and throw an adjustable vacuum advance unit on and a weight kit. Oh, there must be some sort of ballast resistor or a resistor wire on your power to the coil wire that limits the power to 8 volts. You will have to lose that with a heavy guage wire to ensure a full 12 volts to the HEI. otherwise you will not get the full benefits of the swap.
Joe
needs a motor, bad
