| Full Member Join Date: Nov 2006
| lost running lights and dome came on? was driving home 2 days ago truck running fine when all my running and dash lights went out and the done light came on started looking for a short or bad ground found nothing yet any ideas? this is on a 1986 c-20 Don |
| I'm thinking light switch.
| I thought that as well Changed it out (cheap enough) didn't work it is strange the truck has 2 inside lights 1 above seat and 1 under dash when the fuse to running lights blows the 1 under dash blows as well seems to be on the running light circuit the 1 above seat stays on and it is not attached to the light switch has to be a wire shorting out somewhere should be fun finding Don |
| Did you check the plug for the light switch when you replaced it?
| yes it seem ok cleaned it and everything seems ok thought i had it solved found a wire on marker light repaired it and stopped blowing fuses but checked it again later and it blew another one gonna drive me crazy Don |
| Man I hate wiring issues cause they are such a pain to fix. The only thing I can say is what you already know. When the lights go out will your turn signals still work, or the brake lights, or does everything just die.
| found a couple small shorts also still think it is in the switch gonna put in another new one forgot the golden rule of parts (just because it is new does not mean it is good) 1st new switch was not working right it does not function smoothly and head lights on and off if you wiggle the switch also can play with the switch slide and stops blowing the fuse Don Last edited by DonEllis; 04-08-2007 at 06:27 PM. |
| Hope that solves the problem for you!
| well put in another new switch and that seem to have fixed the problem thanks for all the input Don |
| Cool. Glad to see you got it fixed.
