| | #11 |
| Senior Member Join Date: Feb 2007
| so what size rim should i go the width no is 16x7 how big should i go to fit under stock 16x9...???
__________________ 2005 SIlverado 4.8 |
| | #12 |
| if you want a tall truck that is still has the factory suspension then buy a dodge. they make my truck look like an s-10 when i park next to one. i don't think they have that much more clearance than a chevy, but it has more to do with the height of the cab and bed sides. if you don't want your rims, i'll take them off your hands. mine are all flakey and is the worst looking part on my truck.
| | #13 |
| no i want my rims lol thats the whole point they said i can only go from a 245 to a 265 they said if i wanted to go any bigger id have to get wider rims to fit under it stock
| | #14 |
| So can I git 265s not problem i wish I could fit 305s cuz i dont want a lift just a leveling kit
| | #15 |
| When you get tires, the size is a mathamatical ratio, the 305 is the mm in with and 70 is the percent of with to height and the r# is the rim. For example, when you buy a 235/75/r15, you can wider without going taller with a 285/55/r15, you know what I mean? You are just changing the profile. If you are looking for more with, and slightly more height, but not to much, change thopse numbers. if you have 8 in wide rims, you should be able to fit 325's on them, but the profile would have to be much lower. If you want 305's you can do it, but the overall height will have to be adjusted to just about match what you have. Thats about the best you are gonna get. Now if you reall want height, really dude, the only way would be a small lift and wider rims so you can fit more rubber under there. Talk to the guys at the tire store, they will tell you witch ratio gives you what your truck needs. Unfortunately, that would be the choice.
| | #16 | |
__________________ i'd rather be hunting | |
| | #17 | |
Correct the R means its a radial tire. And there is now way to fit 305s on a newer truck without lift, or a sawzall
__________________ Friends dont let friends use body lifts USMC 92-96 USCG 98 to present | |
| | #18 |
| Ok Im listening now what do I do with my sawzall
| | #19 |
| cut a big chunk out of the body around each tire. lol ![]()
| | #20 |
| HAHAHA I should have seen that coming they said if I wanted to put a 285 on it Id have to cut some of the plast at the bottom off
| help with tire size | jjones94630 | Chevy Truck Forum | 3 | 02-13-2007 08:14 AM |
| tire size | johnkraus7 | Dodge Truck Forum | 2 | 01-21-2007 09:46 AM |
| Tire size | MightyHD | Chevy Truck Forum | 3 | 05-04-2006 02:14 PM |
| I Want to Go Bigger on Tire Size | jdmak68 | GMC Truck Forum | 1 | 06-23-2005 12:27 AM |
| Biggest tire size for a Dually ??? | DragracerArt | Chevy Truck Forum | 2 | 03-10-2005 06:20 AM |
