| Junior Member Join Date: Apr 2007 Location: arkansas
| power steering steering box was leaking on my 95 gmc 2wd and when i changed i tried to make sure everything was lined up but when im driving my steering wheel is to the left about 30 deg. there is a flat spot on the steering shaft and on the pitman arm how can i straighten this problem out thanks Last edited by longhaired; 04-10-2007 at 08:31 PM. Reason: left out important info |
| you probaly did everything right even when i change them in the dealer most of the steering wheels end up off center has to be aligned and toe adjusted to correct the concern |
| Power steering | SBHoney | Chevy Truck Forum | 6 | 04-06-2007 09:13 PM |
| Power steering fluid | Old Trucker | GMC Truck Forum | 9 | 03-19-2007 07:05 PM |
| Adding power steering | jt_garyusaf | Toyota Truck Forum | 6 | 06-02-2006 02:21 PM |
| Power steering problems | j_legos | Chevy Truck Forum | 3 | 03-27-2006 05:42 PM |
| Power steering pump shafts keep shearing off | AKHD | Chevy Truck Forum | 1 | 10-25-2005 12:36 PM |
