| try this one hers one for the pros, got a 88 c2500 king cab long bed with a 350, bored .030 a mild cam and a holley tbi, nothing special. when the truck is cold at any outside temp, the truck runs rich, i mean RICH, smell it see it out the pipes and all, and runs rough, now this is at idle, when the engine is cold, but when you go to drive the roughness clears up, then when the truck warms up to about 150 the idle is fine and it is not rich. i replaced coolant temp switch, and put a hotter plug in, no luck. i put a factory tbi on it and i couldnt get it to idle right at all, ran good down the highway but idle really sucked, put the holley back on and delt with the cold idle since. the only engine code i get is from running at highway speeds for about 20 min and a egr code is set. dont know if its the valve or egr sensor but it is dealing with the egr. any ideas, i thought of putting a hotter coil and removing the fusible link feeding the coil so the input volts are not reduced , i havnt done this yet but its my idea. oh and also the manifold vacuum is good and the tps is set to the correct ohms at idle according to holley, mine is adjustable. anyway any different suggestions? thanks |
| Do you have 02 sensor(s)?
| That is a sensor problem. It is reading improperly, and telling the ECM to run it fat when cold. The hotter plugs are actually not helping too much, and depending on the heat range you have stepped up to may cause detonation troubles at higher rpms or temps. Either low end ECM parameters are off (scale is too low), or you have an inop sensor. |
| fuel prob still the sensors are fine, most are new, i have on o2 sensor on the driver manifold, the egr is the only code. |
| You can pull the EGR off and try cleaning it with some carb cleaner. I'm also wondering if you might need another 02 sensor as well. Do you have a dual exhaust or single outlet. If single wonder if you could move the 02 after the y so it can get a more accurate reading.
| well its supposed to run richer when cold. I'd guess that it runs rich all the time, just way more in open loop mode. what are you running for a computer.
| my truck has single into dual. cat foward is a stock set up |
| definately sounds like a sensor issue. maybe the whole computer itself.
| computer is new, been like this since i bought it and the owner sez its been like that since the rebuilt motor |
| keep it simple..... gap your plugs, check continuity of your wires, you might just have a dead cylinder, and if it has been dead for as long as it sounds, it could cause a buildup in the EGR, enough to trip a code. or i'd go as far to say a bad EGR. i'd say clean it and test it with a multimeter. word of advice, dont waste your money on a hotter coil, and definitly DO NOT take out the fusable link. it doenst restrict voltage, its just there to protect from frying something very expensive.
