Old 05-09-2007, 09:14 PM   #1
side door is on a distinguished road
91 s10 4.3 liter
Any suggestions appreciated...
This truck only has 57K on it I bought it a couple of weeks ago. When I start it the idle is VERY high. It runs a little rough when there is no load on it and there is an intermitent ping... I don't know if these problems are related. From what I have read almost all electrical/fuel adjustmets are automatically controlled by the processor soooo there doesn't seem to be a way to make adjustments. My only thought was that it might be the idel air control valve... Anyone have any insight on this??
side door is offline   Reply With Quote
Old 05-09-2007, 10:45 PM   #2
project88's Avatar
project88 is on a distinguished road
i have a suggestion, but it could be completely wrong,
knock sensor, basically a knck sensor will allow the timing to advance as far as it can, but when it detonates, senses a ping and retards timing. My knock sensor was unplugged for a while, never threw a code and had less power and ran rough, got it hooked up and worked fine. High idle could be lots of things,
just my opinion tho, if someone disagrees, thats fine, i submit!
project88 is offline   Reply With Quote
Old 05-10-2007, 08:55 AM   #3
Moderator
Knock sensor sounds like a good idea. as for the idle solenoid i'm not sure. Do you have a check/service engine light? Have you tried to pull any codes even if no light. That is where I would start and see if it'll help narrow things down.
Old 05-16-2007, 08:04 PM   #4
Thanks for the suggestions
I am not getting any service lights but am going to check out the knock sensor this weekend, great idea. Thanks for the suggestions!!
Old 05-16-2007, 08:38 PM   #5
mod-o-tator
high idle could be a vacum leak, the throtle body gasket is usually the problem. spray some carb cleaner around the gasket and if it stutters then you found your problem.
member map add yourself
alldatadiy
Old 05-17-2007, 06:16 AM   #6
jrandalls's Avatar
jrandalls is on a distinguished road
does this truck still have a catalytic converter on it or could it be stopped up? I had a 93 with the 2.8, I removed the cat and had basially the same problems you are describing.
jrandalls is offline   Reply With Quote
Old 05-17-2007, 07:01 PM   #7
dstrick32 is on a distinguished road
Also spray good around the rear of the intake on both sides. This was a common leaking point on the 4.3.
95 Ford F-150XL 5.0 Automatic
92 Chevy Silverado 5.7 Automatic
94 Toyota Ex-Cab 4X4 3.0 Automatic
dstrick32 is offline   Reply With Quote
6.0 Liter slammedram97 Truck Classifieds 2 12-01-2006 07:45 AM
True Dual Exhaust for the 5.7 liter HEMI? Is it possible? ch47hemi Dodge Truck Forum 1 07-28-2006 07:15 AM
6.2 liter chevy diesel chevyguy General Truck Forum 10 07-05-2006 11:51 PM
97 Tahoe 5.7 liter starting problem StevesTahoe Chevy Truck Forum 0 06-07-2005 07:11 PM
7.3 Liter Chip and Exhuast Options leathernmudf250 Ford Truck Forum 0 01-02-2005 04:04 PM
