| Senior Member Join Date: Jan 2007 Location: North Vancouver BC
| brake light my 90 siverado z71 brake light just started to blink today..it blinks like 10 times... pauses for a milli sec..then blinks 10 times...pauses for a milli sec..and so on..any thoughts??...when I put e-brake on , the light stays on...I can hold the e-brake up and no change, the light keeps blinking |
| dude i had a similar prob i had posted but unplug the antilock break **** by the maser cylinder, andplug it back in, iwhat i did was fist unplugged the parkbrake switch to see if it turned off, then i unplugged the proportioning valve to see if it goes off , the last was the antilock brake and that fixed it, mines plugged back in with no brake light prob, i heard that static can build up and cause this to happen , but thats heresay, hope this helps |
| I just took off the negative terminal from the battery for 1 min. or so...reset puter, and all is well again!! |
| i'm pretty sure when the light blinks instead of staying solid it is because the computer is trying to tell you that it is a problem that needs immediate attention instead of the normal "you may want to look at this" light. if i was you i would of had the code read first before reseting the computer, if there is a problem the code will pop up soon, within the next drive or two.
| Brake fluid tip | chevyguy | General Truck Forum | 4 | 03-20-2007 08:43 AM |
| brake light problem | ramdodge | Dodge Truck Forum | 5 | 09-18-2006 07:05 PM |
| Brake light probs | amidaeus | Ford Truck Forum | 6 | 09-12-2006 04:26 PM |
| 1990 chevy 1500 problem e brake light | josh030181 | Chevy Truck Forum | 2 | 08-27-2006 12:29 PM |
| Brake light heartaches | searay25 | GMC Truck Forum | 2 | 08-18-2006 05:10 AM |
