Old 05-19-2007, 05:08 PM   #1
joe cottom is on a distinguished road
85 chevy truck electrical problems
Im fixing up a 85 chevy truck. The truck did run then one day I turned the key and nothing happend. The driving lights work but nothing else in the cab. I've put a new battery, ignition switch, and starter but still the truck wont turn on.
joe cottom is offline   Reply With Quote
Old 05-23-2007, 07:59 PM   #2
pbouffard's Avatar
pbouffard is on a distinguished road
troubleshooting wiring sucks, old truck if you plan on keeping it, go with a painless wiring harness, takes about 2 days to do, and will fix everything.
pbouffard is offline   Reply With Quote
Old 10-24-2007, 06:06 PM   #3
travallenman is on a distinguished road
86 chevy C10 elect issue
I have an electrical issue myself =
This just started. My truck lights/bulbs all work. For some reason when I pull the lights on the Right Green arrow indicator on the instrument panel glows constantly. When the lights are on the right side turn signals do not operate..also the yellow running light on the right side does not light up.....but with the lights off.........all turn singals/lights work fine. The bulbs seem to be good, flasher is working - any ideas? thanks.
travallenman is offline   Reply With Quote
Old 10-24-2007, 06:37 PM   #4
crabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to behold
Welcome to the forum travallenman.
Sounds like a short. Trace back the two non-ground wires coming from the right turn lamp.
You could try replacing the flasher unit, but I think it's an external short.
Think they are the dark blue and brown wires. Happy hunting.
We usually seperate these questions so nobody gets overlooked.
Old 10-25-2007, 06:03 AM   #5
Welcome to the forum joe-cottom.
Suggest you check your fusible links, sounds like one went.
If not, get the voltmeter out and see where you lose battery voltage.
Old 10-25-2007, 09:46 AM   #6
tjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to behold
Crabtruck is right.. check the fusible link wires at the starter solenoin... pull on them to see if they are open inside. If they are the wire coating will stretch and come apart.
Old 10-25-2007, 09:50 AM   #7
travallenman... I would check the bulbs on the front and rear turn signals.. If someone installed a single filiment bulb it will do exactly what you are talking about by feeding voltage through the contacts in the socket. Does the indicator come on when you step on the brakes?? if not then check the front one first.
Old 10-25-2007, 04:41 PM   #8
Nice cheat with the brake tjzz4, I missed that.
Old 10-25-2007, 04:56 PM   #9
The best and easiest to understand book on electrical troubleshooting I have found is "How to diagnose and repair automobile electrical systems" by Tracy Martin. If is available on amazon for the ridiculous price of $12.45 After reading it I understand and have been able to fix every single electrical problem I came up against...quickly. No relationship with author but it is one of the very few books that I have two copies of and have read more than once. If you ask me it is worth its weight in gold.
Old 10-25-2007, 05:29 PM   #10
You must like it, you've endorsed it twice this month LOL
Read the reviews on it and while it doesn't cover a lot of stuff,
many folks really seem to find it helpful.
We should probably have a section somewhere for good books
and websites with useful resource data.
Can be hard to find when buried in posts.
Help a Student..Take a Truck Survey ClassSurvey General Truck Forum 2 12-08-2007 06:51 PM
1994 Chevy pickup electrical problems seniorjudge Chevy Truck Forum 4 01-02-2007 08:17 AM
1994 chevy truck electrical problems ohio larry Chevy Truck Forum 0 12-25-2005 10:09 AM
chevy truck drivetrain swap, questions.... beachbum29 Chevy Truck Forum 3 11-23-2005 05:23 AM
TEN Magazines(TM) Announces Ford Truck World, Dodge Truck World, and Chevy Truck World Now Published Quarterly With (The Auto Channel) trucknews Truck News (headlines) 0 10-29-2004 05:30 PM
