Old 05-26-2007, 08:45 PM   #1
chevyman_03 is on a distinguished road
Lift Question.. NEED HELP
I own a 2003 Z71 silverado ext. cab, it has a 4" pro comp suspension lift and 35" bf goodwrench tires. I have some 40" tires avaliable to me but they will not fit in the tire well of my truck with only a 4 inch lift. Is there anyway to further lift my truck a few inches without purchasing a new lift kit?
Need input!! THANKS!
chevyman_03 is offline   Reply With Quote
Old 05-26-2007, 10:19 PM   #2
72'CaminoKid's Avatar
72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold
body lift or cut the fenders
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 05-27-2007, 07:14 AM   #3
mod-o-tator
don't cut the fenders, sawzalls are not your friend.
member map add yourself
alldatadiy
Old 05-27-2007, 10:02 AM   #4
theres already a small portion of the fender cut... i dont wanna have to cut them further, and from the body lifts ive seen i dont like the way they look... but they are apealing from a financial aspect
I'de rather PUSH a chevy... then DRIVE a ford.
Old 05-27-2007, 04:39 PM   #5
so basically theres no way i could alter my current lift kit to achieve more lift ??
Old 05-27-2007, 05:28 PM   #6
Moderator
If you don't already have block in back you could add some, or do a shackle flip. The front being IFS you gonna have to go with a bigger lift.
Old 05-27-2007, 06:13 PM   #7
yea i have blocks in the rear... and ive been told a shackle flip could work too... but this helps to get other ppls opinions..
thanks, everyone !!
Old 05-27-2007, 09:41 PM   #8
i dont like BL either but it is what your lookin for.....
why not cut fenders?
99 suburban xlt
96 silverado
Old 05-28-2007, 04:48 AM   #9
mod-o-tator
as long as you get some fender flares to cover everything up i don't have a problem with cutting them, but it's to easy to get carried away.
alldatadiy
Old 05-28-2007, 09:35 AM   #10
While 40" tires are cool to look at, the truck may not be to happy about the install. It will require more lift to clear them, that is the easiest part but you will also need to change the gears in the axles. Assuming that you are still running stock gears there now, it struggles with 35" tires, and stepping up to 40's is really going to make that thing work much harder. Now, the 10 bolt axle and the tiny front diff, little cv's are deffinately not up to the task of keeping those big tires motivated, not to mention, once you get them rolling, the brakes are pretty small, and will find difficulties in getting the vehicle stopped.
The 4L60E transmission is also going to have some difficulties with the larger combo, they just do not like that much of a load.
Just hope you take everything into consideration before you run right out and slap some big meats under there. There is much much more than meets the eye here.
Lift Question Hayden Chevy Truck Forum 19 07-11-2007 04:17 AM
body lift for '89 2wd w/power steering (question) tri5ron Toyota Truck Forum 0 04-20-2007 11:51 AM
95 Z-71 lift question alex11b Chevy Truck Forum 9 11-17-2006 12:36 AM
Lift Questions JenksBaseball Dodge Truck Forum 5 07-22-2006 11:04 PM
73-87 Chevy Suburban 2wd Lift Kit Question JIM Chevy Truck Forum 0 05-27-2005 10:07 PM
