Old 05-27-2007, 10:39 AM   #1
starvin4speed is on a distinguished road
Question Replaced distributor - timing is wrong
I replaced my distributor, cap, rotor, wires and plugs, installed a K&N intake, throttle body spacer.
Problem: I forgot to mark the distributor position. I had a brother in law help set the timing, truck runs but cranks slow and service engine soon light stays on after we cleared it. Code shows problem with distributor. Can I, a novice, set the timing or should I take it to dealership?
After lining up the marks on the crank pulley and block, B-in-law removed distributor and reached into the opening with a long screwdriver and attempted to reset doohickey inside engine. Truck cranks and seems to run, although idles a bit fast and drags when cranking, sometimes it almost starts and dies, then cranks on the next try.
Help, I would like to fix this myself if possible, but I don't know anything about setting the timing.
starvin4speed is offline   Reply With Quote
Old 05-27-2007, 12:29 PM   #2
Moderator
what year truck? if it is 96+ you need a realtime computer to check and set timing. If it is pre vortec there is a brown wire on the passanger side next to the ac stuff. You have to unplug that while setting timing.
Old 05-28-2007, 06:01 AM   #3
Smile Thanks
Thanks Duke, it is a 1998 vortec, I guess I will take it to the dealership service dept.
thanks again
Old 05-28-2007, 09:49 AM   #4
Moderator
no problem
What to do and what not to do when.... Ford4x4Chik27 Off-Topic 2 10-02-2006 05:34 PM
2004 TBI Replaced!! Rawdeal Phil Chevy Truck Forum 4 03-27-2006 07:31 PM
brakes overheat bigtime but i replaced everything jazzzmonky Ford Truck Forum 8 11-13-2005 11:55 AM
Off road: Hamilton Jr. is replaced for Sonoma (Tennessean) trucknews Truck News (headlines) 0 06-23-2005 03:30 AM
Ford Owned Off-Road Giant, Land Rover Splashes Mud on the Wrong Guys (PR Web via Yahoo! News) trucknews Truck News (headlines) 0 07-28-2004 01:30 AM
