Old 06-04-2007, 05:13 PM   #1
TZR2 is on a distinguished road
Squeaking Noise?
I have a 2000 S10 ZR2, when I am driving around I can hear a constant squeaking noise coming from the driver's side rear wheel area. My foot is not on the brake either. It goes away when I stop or when I drive over 60 km/h. Does anybody have any ideas what this could be, or had a similar problem?
TZR2 is offline   Reply With Quote
Old 06-04-2007, 08:03 PM   #2
2000' disc brake rear?????
Think it is telling you that you need new pads.
Little metal plate installed on the pad designed to tell you, "i need to be changed, squeek, squeek, I need to be changed, squeek, squeek."
Listen to it, or it will yel at you, "I should have been changed, grind, grind."
You get the idea.
If it has drums, could be the same thing, just gonna have to pop the drum off to inspect.
Bet a cold beer it is from bad pads / shoes.......
Old 06-04-2007, 08:22 PM   #3
lol^^^, you almost made me choke on my sub.
i'd rather be hunting
Old 06-07-2007, 08:58 PM   #4
Ok, so I changed the rear break pads and the roters. Then I was driving and I could hear a sound like clunk... clunk when I was driving slow. Took the tires off and took another look. I noticed that the calipers stay closed after releasing the breaks. Any suggestions? Do I just need to bleed the break fluid?
Old 06-07-2007, 09:01 PM   #5
Perhaps the slider pins are dirty, and not allowing the caliper halves to move properly. May have to remove the caliper again, and clean / lube the pins.
Old 06-07-2007, 09:28 PM   #6
how did you push the piston into the bore, you may have the type of emergency brakes that require the piston to be screwed into the bore instead of being pushed in. did you notice groves in your piston when you had it apart, if so then the piston should have been screwed in. also the pads should always have slight contact with the rotor to keep road junk off the rotors, unless you can hear the brakes drag while you spin the tire then you should be okay. worst case senerio may be new calipers.
1994 c1500 - clicking noise from heater Chris Chevy Truck Forum 19 02-11-2009 07:10 AM
Squeaking noise comming from rear end? TopCal2500hd GMC Truck Forum 1 02-22-2007 09:03 PM
A/C Noise - 2001 Chevy Tahoe sandman3175 Chevy Truck Forum 4 08-16-2006 07:34 PM
Squeaking Noise When I Drive travolta GMC Truck Forum 5 08-14-2006 07:11 PM
Strange squeaking noise Beaver3000 GMC Truck Forum 6 09-11-2005 04:31 PM
