Old 06-07-2007, 10:27 AM   #1
rednekracer is on a distinguished road
Upper Control Bushings
I need to replace front upper control bushings on 1995 Z71 4x4. Are they pressed in or can they be tapped in with hammer. Any tips would be helpfull. Thanks!!!
rednekracer is offline   Reply With Quote
Old 06-07-2007, 11:39 AM   #2
Going to take a little heat and a press. Be carefull not to bend the arm.
Old 06-07-2007, 08:08 PM   #3
mook6979's Avatar
mook6979 is on a distinguished road
are you sure you need to replace them? i have a 96 k1500 and i thought i needed bushings but they were adjustable and a couple of guys i talked to said they rarely wear out. i just adjusted mine and its as tight as new.
mook6979 is offline   Reply With Quote
Old 06-08-2007, 10:19 AM   #4
But there shouldn't be any play at the bushing. When I jack up my truck i can hold the wheel and move it back and forth and see about .25" of movement at the upper bushing. I found out the control arms from Chevrolet have bushings installed and are about $120.00 per side. I think I'm going to replace the whole control arm instead.
Old 06-08-2007, 04:39 PM   #5
mook6979's Avatar
the bushings are cammed i did not adjust mine myself but a gm mechanic that is also a friend adjusted mine. my truck had so much play in the bushings i failed inspection. it is worth looking into it saved me a couple hundred dollars easily
Old 06-10-2007, 10:25 AM   #6
I have 230,000 miles so I've decided to go ahead and replace the upper control arms and upper ball joints. Thanks for the advice and help you guys give.
Fabtech Bushings LC4short Chevy Truck Forum 5 02-09-2007 10:15 AM
IFS control arm poly bushings jasonjamesoren Toyota Truck Forum 3 07-31-2006 07:25 PM
2001 GMC 2500 Cruise Control Problem jim5434 GMC Truck Forum 1 07-18-2006 01:03 PM
Cruise Control Lever 1988 Jimmy cheesebone GMC Truck Forum 2 06-27-2006 08:44 PM
