| Senior Member Join Date: Feb 2007
| What PSI Should I have my tires at I just got brand new Nitto Terra Grapplers 265/70/17 it says at full capacity that it should be at 35 PSI what should i have it at for highway and street driving no off roading I have it at 27 PSI
__________________ 2005 SIlverado 4.8 |
| Senior Member Join Date: May 2007 Location: Maine
| best thing to do is take some windshield white marker and place 2" strip across each tire. Drive down the road a few hundred feet. If you have the correct tire pressure the marks will be worn off the tire evenly across. |
| Full Member Join Date: Feb 2007
| I have those tires on my z71 and I run 35 psi in mine. I rotate the tires at every oil change and check the alignment every. Mine are wearing evenly across at 35 psi. I haven't had any problems out of my nitto's except that they are hard for my tire store to get. |
| If they are hard to get go to ebay. Tire direct has them for sale on line and most of the time shipping is free and the tires are cheaper. |
| But should 27 28 PSI alright?
| try the test. thats the only way to make sure that your gonna get even tread wear. |
| i usually run mine 10psi below the max stated on the side wall.
| the best thing to do is to go with the most psi that even tread wear allows. Whats easier to roll, a marshmellow or a marble? |
| BowtechAndy is right on the money here. Funny that most people are quick to run out and spend money on "gizmo's" that claim to get better mileage, and most never bother to take a few moments to inflate thier tires properly. A proper inflation is the most imoprtant key to long tire life, and the best overall gas mileage. Wheel width and the curb weight of the vehicle will vary from vehicle to vehicle. The tread pattern test is a fantastic idea, and really the only way to determine a proper contact patch with the ground. Manufacturers recommended valuse are there for a reason, running tires under inflated is entirely up to you, but added tire wear might result, and less gas mileage can be expected. |
| I usually run mine from 5 below(unless I am going to drag strip), but take in mind it will make a difference where your weight is on you vehicle and if you are hauling a lot of loads.
__________________ MEOW!! |
| big off-road tires have got to be bad for these little 4-bangers | mochester | Toyota Truck Forum | 29 | 07-29-2007 05:01 PM |
| LT tires | farmermj2 | Dodge Truck Forum | 4 | 04-24-2007 11:26 AM |
| Fs: 17" Nissan Truck Wheels And Tires | tsj9197 | Truck Classifieds | 1 | 10-02-2006 09:27 PM |
| Big tires and power/gas milage of 22re | mochester | Toyota Truck Forum | 3 | 06-15-2006 12:39 PM |
| SUV/Truck Tires provide smooth ride in extreme weather. (ThomasNet) | trucknews | Truck News (headlines) | 0 | 02-04-2005 09:30 AM |
