Old 06-14-2007, 09:53 PM   #1
pumba is on a distinguished road
Mp-efi, Conversion,
I was looking at: EDELBROCK MULTI- POINT EFI CONVERSION KIT,Has anyone done this?and if so did it help with power,or fuel mileage?I did a search,but found nothing about it?
pumba is offline   Reply With Quote
Old 06-14-2007, 11:06 PM   #2
Try not to set very high expectations if you are looking for more power. The injection is only going to be more efficient. If your carb is doing a poor job of mixing fuel and air, you may see a slight increase in performance but is not very likely. Well that is depending on the size of your carb. If you are running a very smalll carb and the CFM is greater with the injection unit then you will see a perfromance difference, but if you are comparing equally flowing units, then no.
A good carb is tough to beat, but can be a bit tricky to get set up. The biggest advantage to electronic fuel injection, is its ability to monitor itself, and make corrections to alter air / fuel ratios.
Injection can also be an advantage in rough conditions such as off-road, or boating where the fuel in the carb bowls can slosh. With injection, it will work at any angle.
Just a thought, those systems are pretty expensive. If you are looking for power, and of course if you are building a chevy, why not consider a set of late model Vortec heads and late model injection with an ecm and harness from a donor vehicle. You would spend about the same money, and then you would realize better performance.
Little more difficult to do with a ford, or chrysler, but easy as pie with a bow tie.
454 conversion finally!! nealsw Chevy Truck Forum 6 03-03-2007 06:47 PM
1995 nissan conversion te0417 Nissan Truck Forum 13 11-20-2006 06:16 PM
Hello, Need help about a possible engine conversion? bishopj76 Introductions 2 07-31-2006 07:55 AM
95 Chevy Conversion Van Mckheean Truck Classifieds 7 07-08-2006 07:31 PM
97 4.2 v-6 conversion Goatman247 Ford Truck Forum 5 03-17-2006 07:54 AM
