Old 06-15-2007, 07:10 AM   #1
chevy86 is on a distinguished road
350-motor uses OIL but doesn't leak it
Until I get the motor rebuilt, is there an actual additive that helps stop excessive oil use - I think its the valve guide seals. When I first start it up a little blue smoke rumbles out the exhaust when throttling it up. For the next oil change which I haven't done just yet, I bought an larger oil filter (2-quart cap.) and 10-40 and a quart of Power Punch for lube purposes, what else might help keep things together until the rebuild commences? Would a thicker oil also help this?
thanks
Sam
chevy86 is offline   Reply With Quote
Old 06-15-2007, 09:34 AM   #2
Moderator
I've heard some good things about Lucas. Don't know if it will help stop the leaking. You sound right saying it is the valve seals. That is the most common cause of smoke at startup.
Old 06-15-2007, 03:29 PM   #3
The part that caught my attention, was the "smoke when throttling up".
Super hard on internal components if you are having to, or wanting to rev the engine up while it is cold. Cold components do not like that very much.
a slight increase in the weight of you oil may help some, but often just quiets noisy components down, and there is not too much out there that is going to fix leaks. Sure there are some conditioners that may help some rubber seals, but if it is a gasket, no miracles that I know of.
Take it easy on the old girl until you can gather the cash to get her re-built.
Old 06-15-2007, 03:55 PM   #4
72'CaminoKid's Avatar
72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold
could also be the rings. but i agree. just take it easy on her until you cna rebuild it
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 06-15-2007, 10:17 PM   #5
ddraszt is on a distinguished road
lucas makes a great oil additive also theres an additive called restore that works well or at least has for me on some smokin rings. SAE 30 seems to help a little keep that thicker vicosity. just a couple thoughts.
"It is what it is"
ddraszt is offline   Reply With Quote
Old 06-16-2007, 10:53 AM   #6
mech34us is on a distinguished road
Thumbs up Some Ideas
I would us a 20-50 grade oil that is thick and use lucas or restore both very good products.
mech34us is offline   Reply With Quote
Old 06-26-2007, 08:16 AM   #7
sport is on a distinguished road
i agree with using lucas.. mt neighbor swears by it
sport is offline   Reply With Quote
Old 06-26-2007, 02:23 PM   #8
Moderator
why not just replace the valve seals. afternoon project that is not difficult. stop by and pickup a valve spring compression tool and seals and valve cover gasket. just remember not to drop the valve or lose the locks that go around the valves.
Old 06-28-2007, 01:08 PM   #9
Ford4x4Chik27's Avatar
Sounds like piston rings to me
Old 06-29-2007, 08:17 PM   #10
scottie's Avatar
i second brad with the valve seals
76 Chevy 454 - massive oil leak in rear of engine MrDavidOgle Chevy Truck Forum 19 10-07-2007 01:46 PM
Evap Leak Sssniper Chevy Truck Forum 3 05-09-2007 07:31 AM
2001 Suburban oil leak help DesertCraw4th Chevy Truck Forum 1 04-25-2007 06:59 AM
coolant leak marko Introductions 1 01-27-2007 04:04 PM
Help Power steering leak kruszka Chevy Truck Forum 9 05-05-2006 11:50 AM
