Old 06-17-2007, 07:10 PM   #1
jasonv100 is on a distinguished road
front wheel noise
i have a 2002 crew cab chevy s10,and i got this noise in the front wheel.as the car is bouncing i got this screech sound,all the time.every bounce.i sprayed wd 40 on everythimg i could see ,and nothing at all.it sound like it is the hub. any info would help thanks
jasonv100 is offline   Reply With Quote
Old 06-19-2007, 08:17 PM   #2
scottie's Avatar
maybe a wheel bearing, pretty common thing to fail and replace
Old 06-19-2007, 08:28 PM   #3
72'CaminoKid's Avatar
jack the front end up and try and wiggle the tire back and forth (not the direction of rotation). if you're lookin at it from the front or back i guess you could call it side-to-side. if it has alot of play in it your wheel bearings are shot
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 06-20-2007, 07:08 PM   #4
tried it
i jack it up and check if anything was loose and nothing wiggled.
it sounds like it is coming inside the hub,even when the car is in park,i wiggle the wheel back and forth,and i can hear it screeching.i cant seem to pin point it out
Old 06-20-2007, 08:16 PM   #5
the squeek could be a dry shock. The squeel sounds like brakes
Old 06-20-2007, 10:59 PM   #6
It is the torsion bar. Check where it meets the crossmenber (pork chop) or the hex at the control arm. Dry sockets with torsion bar front ends do this all of the time.
If you had a conventional spring and heard this noise, you would have described a squeeky spring, well, the torsion bar is just that a spring, it is only spirally wound, but still subject to the same resistance in the same contact areas.
Need help diagnosing noise from wheel... gunner1 Chevy Truck Forum 18 05-14-2007 07:37 PM
can not remove front wheel hubs rcs34 Dodge Truck Forum 1 01-31-2007 07:30 PM
Front door popping noise cwmoss Chevy Truck Forum 2 09-10-2006 02:18 PM
92-99 K2500 wheel backspace question Fortyfied GMC Truck Forum 3 07-21-2006 04:37 PM
universal joint on front drivers side wheel ramdodge Dodge Truck Forum 3 07-16-2005 12:02 AM
