Old 06-18-2007, 06:20 PM   #1
mcarriker's Avatar
mcarriker is on a distinguished road
2001 4x4 A/C Relay failure?
hey everybody,
got a lil problem.... my A/C blower motor only blows when turned to settings "4" and "5"... 1,2, and 3, do nothing, what the problem, is it a failed relay??? thanks alot
-mark
mcarriker is offline   Reply With Quote
Old 06-18-2007, 07:42 PM   #2
scottie's Avatar
sounds like a worn out potentiometer in the heating control panel itself
Old 06-19-2007, 11:03 PM   #3
NCroadracer's Avatar
NCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud of
Most likely a bad blower motor resistor. Very easy to replace with common tools and not too expensive.
NCroadracer is offline   Reply With Quote
Old 06-20-2007, 03:38 PM   #4
mcarriker's Avatar
alright, well i've noticed that th blower motor is on the interior of the firewall, has anybody done this procedure, what can i expect, what do i need to yank off to get to my blower motor? thanks for help!
-mark
Old 06-20-2007, 04:35 PM   #5
No need to remove the blower motor...Just the resistor. It's locater just forward of the blower motor (Under the passengers side of the dash) and is held in place with two 5.5mm bolts. at should have like 6 wires going to it.
Old 06-21-2007, 12:40 PM   #6
mcarriker's Avatar
alrighty, thanks, also;
Is there any way i can test if this resistor is bad?
-mark
Old 06-21-2007, 04:25 PM   #7
If the switch is putting out B+ to the resistor in 4 and 5 setting, the resistor is most likely the culprit. If you still wanna check it to be sure place a test light from the neg to the Pos terminals going to the blower motor....It should light in each blower motor speed setting, getting more intense with each speed higher.
Add another fuse for new headlight relay? Fortyfied GMC Truck Forum 3 04-06-2007 05:25 PM
Stuck Relay!!!! twanger1994 Toyota Truck Forum 7 01-23-2007 07:38 PM
Help OBD Port will not read 2001 yukon Boydo GMC Truck Forum 3 01-14-2007 11:40 AM
2001 Infinit QX4..programming buttons on visor Dave8792 Nissan Truck Forum 1 08-22-2006 08:03 AM
2001 GMC SLS Extended Cab Pickup For Sale Craftsman729 GMC Truck Forum 0 08-21-2005 02:38 PM
