Old 06-28-2007, 12:32 PM   #1
dreambig73's Avatar
dreambig73 is on a distinguished road
Excessive cranking 86 Chevy
My truck is a 86 P/U with a 350 (not original, probably from a van a year or two newer) carb, HEI. When I try to start it cold a lot of times it will almost start then die. Then I try to start again and it wants to crank for 5-10 seconds while I pump the throttle. Once it starts it runs fine. Sometimes it even takes a few seconds to start it hot. What could cause this? Maybe needs a tune up? The carb was just adjusted over the winter.
dreambig73 is offline   Reply With Quote
Old 06-28-2007, 12:50 PM   #2
could probably use a tune up. Timing might be a little to far advanced. Might want to give it a check.
Old 06-28-2007, 01:52 PM   #3
Ford4x4Chik27's Avatar
Ford4x4Chik27 is just really niceFord4x4Chik27 is just really niceFord4x4Chik27 is just really niceFord4x4Chik27 is just really nice
I'd say timing or spark. But it could be one of a million things really.
'93 Isuzu Amigo, Toyota Axles/Tcase/Drivelines, 35" MTR's. '01 Pathy, DD.
A fact of life: After Monday and Tuesday, even the calendar says W T F.....
Old 06-28-2007, 03:53 PM   #4
dreambig73's Avatar
Thanks. I'll start with checking the timing. I figure it needs a t/u anyway.
Old 06-28-2007, 08:44 PM   #5
Sounds to me more like the fuel pump bud. If the diaghram is bad, or leaking, it will not hold pressure and allow the fuel bowl to drain. Once the bowl is empty, it takes a while to crank until it fills again. Once it does, she runs fine. It mat even run, and start well untill it sits for a while and the fuel drains back out of the bowl.
You could change the mechanical pump, or install an electric one, and a regulator. The easiest is to just install a new pump. SBC pumps are a dime a dozen. Two bolts and presto, thing should start every time.
Old 06-29-2007, 05:37 AM   #6
03chevy's Avatar
03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future
i would say more of a fuel pump problem instead of a tuneup problem unless it has been a long time ago for a tuneup
True Chevy Lovers Help Me Please!!! Y Is Chevy Better Than Ford?! chevygirl4life Chevy Truck Forum 81 03-09-2008 11:26 AM
2000 Chevy 4.8 5-speed 2wd Cranking Problems 06BLACKGMC Chevy Truck Forum 2 05-05-2007 03:27 AM
Question Chevy vs GMC Truck_Man General Truck Forum 63 04-16-2007 09:15 PM
Late Chevy truck wheels on early truck Unclejunk Chevy Truck Forum 1 01-08-2007 06:51 AM
1989 chevy value 396chevy Chevy Truck Forum 6 09-27-2005 10:23 PM
