Old 07-04-2007, 10:56 PM   #1
joey40949 is on a distinguished road
Talking gear help
i have 1996 chevy k1500 i have 6inch lift and 3inch body lift installed the suspension was just installed today im currently running my 305/75/16 on there which look real small on there but i have a set of 37x13x16 superswamper boggers on 16x9 wheels i wanna put on but right now i have the stock gearing and dont have the extra money for gears at the moment my question is would my trannie hold up for a lil time till i can get a set of gears i have cold air intake dual exhaust throttle body spacer accel ignition coil and msd 8.5 mm plug wires for lil more power i mostly will be street driving but i hunt and do alil mudding on the side
joey40949 is offline   Reply With Quote
Old 07-05-2007, 05:05 AM   #2
I wouldnt get too carried away with it until you can get some gears in it.
Old 07-05-2007, 11:14 AM   #3
Very good advice from mrjohnwayne. That 4L60E will not like the 37" tires at all.
Is that truck equpied with 3.73's or 3.42's?
May never even get high gear and lock up with 37's, and 3.42's, unless you are going over 90 miles an hour. Even the 5.7 will have a difficult time doing that.
Old 07-05-2007, 11:46 AM   #4
ok thanx ill just wait then but i asked my friend who was running 37inch iroks on his 2004 chevy 1500 5.3 he was running 3.73 and he said his truck pulled them fine
Old 07-05-2007, 12:14 PM   #5
usually guys that do not know say this same thing. They do not have anything to compare to. If you were to take the same trucks and install the right gears, and the wrong ones, you would later ask "WTF was I thinking driving around like that?"
It is a night and day difference. Will the truck pull them? Yes it will, but does it do it well? Not really. The thing runs like a **** and doesn't have to. The engines are not torque monsters, so why make it work so hard?
Old 07-05-2007, 12:44 PM   #6
ok thanx i got enough money to regear the rearend and take the driveshaft out of the front till i regear it which be in a week or so wont have 4wd but its gonna mostly be driving to work neways is that an ok thing to do?
Old 07-05-2007, 12:58 PM   #7
You really do not have to take the driveshaft out, as long as you never engage 4wd. The axle disconnect will prevent any damage, and the case will be in 2wd so no troubles should be expected.
You should install the tires, and do the gears in a few weeks all at the same time You will not hurt anything by waiting a little while. It will also give you a chance to drive it without the gear change, and compare it to the new gears, so you can see for yourself the big difference. Then when somebody telss you that they are using high gears with no problems, you will know first hand that they just do not have much of a clue.
You are going to go with 4.56's?
Old 07-05-2007, 02:05 PM   #8
well havent decided was gonna go 4.88s because after the 37s wear out was gonna get a set of 38.5inch boggers but if i could pull 38.5s fine with 4.56 i would cause i might go with 37inch iroks instead since it is my daily driver i know ppl think u shouldnt run any superswampers on a daily driver but my dad ran his 44inch superswampers on his 80 cj for 7 yrs and it he drove it everyday i know i wont get that out of boggers or iroks but ill be happy if i can get 20000 miles out of them
Old 08-01-2007, 11:23 PM   #9
well i got my gears ina few weeks ago and it did make a big difference but the other day i noticed my transmission will not **** in 1st or 2nd manually if u **** it either gear it will move but seems like the trannie is slipping but u can but it in drive or overdrive and it shifts great through all gears downshifts and everything i changed filter and fluid to see if it would help and it hasnt what could it be?? my dad is a diesel/auto mechanic he said he thinks the clutches are out what do yall think?
Old 08-01-2007, 11:39 PM   #10
I would have to check some books, and even some old records, but I recall this being a common solenoid problem. I do not think it is slipping, I believe it might be taking off in second gear.
S-10 souping, gear ratios, exhaust? buumachine Chevy Truck Forum 2 12-12-2007 11:27 PM
Gear swap 4.10 to 3.73 jrtone Dodge Truck Forum 2 02-03-2007 06:10 PM
Speedo drive gear color RB35 Ford Truck Forum 0 08-04-2006 11:04 AM
what is causing gear shifter not to move on a 94 1 ton 5 speed trans makinitgood2u Chevy Truck Forum 3 02-13-2006 01:02 PM
Gear Ratio??? Billy2001Z71 Chevy Truck Forum 4 06-19-2005 02:27 PM
