Old 07-17-2007, 07:07 AM   #1
larbec7 is on a distinguished road
How do you drain the anti-freeze 95 K-1500
I have a 1995 K 1500 Cheyanne and I cannot find the drain **** on the radiator. Can someone [please tell me where it is so I can change the anti-freeze. Everyone i ever saw was on the bottom of the radiator. I have had a broken neck so my neck does not turn good...so if that is where it is I may have missed it.
Thanks
larbec7 is offline   Reply With Quote
Old 07-17-2007, 07:17 AM   #2
Given the age of the vehicle, the drain may not be a ggo idea to try to remove. It will be fragile, and more than likely break. You may just want to remove the lower hose to drain the fluid.
Old 07-17-2007, 07:20 AM   #3
I will look at this tonight. I just purchsed this truck for my 17 year old and the radiator was serviced according to a report by the local garage BUT it is full of rust....so I wonder was it EVER serviced
Old 07-17-2007, 10:10 AM   #4
Moderator
"service" could mean as little as drain and fill. they may not have done a full system flush.
member map add yourself
Old 07-17-2007, 10:32 AM   #5
I have never seen so much rust before in a system
Old 07-17-2007, 10:44 AM   #6
Moderator
what state are you in? if your in a warm climate then there could be more water than there should be in the system. could be a sign of a coolant leak and the owner toped it off with the garden hose periodical. i would have the system pressure tested being it is a used truck to make sure there are no leaks.
Old 07-17-2007, 07:52 PM   #7
scottie's Avatar
if you have a voltmeter, you could test it becuase as old coolant can start creating a voltage. a coolant drain and fill would be easy and cheap enough... i'd suggest taking off the radiator hose as mentioned by 75K30, thats what i do with my '91
Old 07-20-2007, 09:11 PM   #8
Super Step is a name known to allSuper Step is a name known to allSuper Step is a name known to allSuper Step is a name known to allSuper Step is a name known to allSuper Step is a name known to all
Isn't the drain valve plastic?
I have a '94 Silverado (I know there were style changes in '95) I just went outside to make sure and mine is plastic.
Pop the hood. Look on the lower right hand side of the radiator. It is not on the bottom like older models. There is a rather large plastic valve near the bottom of the shroud. I do not believe mine unscrews, just rotates to line up the drain hole (I could be wrong on that).
If it is indeed plastic, I would not be as concerned about the valve itself being corroded.
Good luck. I hope your son enjoys the truck. Brings back memories.
Super Step is online now   Reply With Quote
Old 07-22-2007, 06:11 PM   #9
Sneakysportsman's Avatar
Sneakysportsman is a jewel in the roughSneakysportsman is a jewel in the roughSneakysportsman is a jewel in the roughSneakysportsman is a jewel in the rough
Drain Plug
It is on the driver side close to the bottom, Here is a pic to help, it is the white nut shape, some are eve n black. Hope this helps.
Sneakysportsman is offline   Reply With Quote
Old 01-29-2008, 09:09 PM   #10
robs98silverado is on a distinguished road
Wink
Thanks
As you are facing the engine of the truck, the antifreeze petcock is on your bottom lower right hand side of the radiator..... it's always oposite side of the lower water hose! Usually black and resessed into a plastic cup or lip. Twist left then strait out...... with a jiggle motion if appearing stuck! Note it doesn't screw all the way out like a bolt does..... it's a lot like a medicine cap lid......Use a set of needle nose or regular pliers to remove it. After you remove it check the O ring that's around the end allowing it to seal, if it looks alright and usable put a little soap or detergent on it to help it slide back into cavity after your drain is complete! If there is a lot of rust in system leave the drain plug out while flushing with a steady flow of a water .... put the hose down in the top of radiator and start the truck, it helps to turn on the heater as well to ensure that the heater core gets a good flush as well during this cycle! After a five minute flush with fresh clean water, turn engine off.......let it drain out completely.... then place the drain plug back into the radiator. It's a good idea to let the truck totally cool before adding any fluids, this will ensure that there will be no steam flashes in your face and eyes blinding you.....! I'd suggest at least a 50/50 blend of water to antifreeze in any climate.... I worked at the truck and bus plant in Dayton, Ohio for years.....I assembled these things all day..... Yes, only certain changes were ever made but they all drain the same ways! No matter the year! .....
robs98silverado is offline   Reply With Quote
1999 Chevy 1500 tune up dokutman Chevy Truck Forum 2 12-07-2006 03:55 PM
Anti freeze leak none on ground 92Jag Chevy Truck Forum 29 10-16-2005 10:16 PM
