Old 07-17-2007, 11:46 AM   #1
Kansaskeith is on a distinguished road
Angry '98 Chevy 1ton brakes locking diesel dually
HELP! Got a 1 ton diesel dually been to the wrench several times - throwing shoes - locking up - been a real pain! any suggestions, besides a new mechanic?
Kansaskeith is offline   Reply With Quote
Old 07-17-2007, 12:00 PM   #2
peterbilt's Avatar
peterbilt has a spectacular aura aboutpeterbilt has a spectacular aura aboutpeterbilt has a spectacular aura about
a new truck? mixxing up the pimary or secondary shoes, no lubrication, e brake cable stretched, or a wheel cylinder is bad. does this help?
1971 Volkswagen Bus Deluxe
1998 Ford Ranger XLT
"Never give up on somebody you can't go a day without thinkin' about"
Eric and Jessica 1-14-08
peterbilt is offline   Reply With Quote
Old 07-17-2007, 12:16 PM   #3
Rear brakes stuck!
I'll check it out! The mechanics put on 3 sets of shoes, thought the first one's were bad (rivets)? Starts out OK then after some driveing - backing ect. started locking up again! How about just disconnecting the emergency brake? to narrow it down? Don't use it anyway! Thanks for your reply! Kansaskeith
Old 07-17-2007, 12:20 PM   #4
peterbilt's Avatar
my dad eliminated the e brake in the econoline. so you could do that. make sure they are put them on strait.
Old 07-17-2007, 12:23 PM   #5
Ford4x4Chik27's Avatar
Are they hydraulic? Have you replaced your Master Cylinder? Brake Booster?
Old 07-17-2007, 01:17 PM   #6
Moderator
if they still use shoes I'm thinking the auto adjusters are the problem. if they keep tightening whenever you back up that will cause them to lock up.
Did you just replace the shoes or all the hardware, springs, keepers etc?
mrjohnwayne is online now   Reply With Quote
Old 07-17-2007, 04:04 PM   #7
Moderator
if it is throwing the shoes i would check the drums. if the drums have grooves in them they will act like threads and pull the shoes off the retaining pins and return springs. did the mechanic turn the drums? he may have turned them on to high of a speed and created this problem. also lock up can be caused by contaminated shoes. i would check your axle seals for leaks and also check your wheel cylinder for leaks.
member map add yourself
Old 07-17-2007, 04:08 PM   #8
Moderator
if your E-brake was siezed up you would not be able to get the drum back on with the new shoes installed. i had that problem with a ford ranger i worked on. i doubt the E-brake is your problem.
when did this problem occur, before or after the mech. touched them?
Old 07-17-2007, 04:15 PM   #9
peterbilt's Avatar
convert to dics.
1987 chevy one ton dually for sale skip Chevy Truck Forum 0 05-21-2007 06:07 AM
rear brakes locking up dusted800 Chevy Truck Forum 3 03-24-2007 08:42 PM
Chevy new HD diesel . Anyone seen one? chevyguy Truck News (headlines) 3 02-28-2007 02:08 PM
94 Chevy Turbo Diesel For sale Felix Harsh Truck Classifieds 5 05-23-2006 10:58 AM
1997 Chevy Silverado 2500 Turbo Diesel Big Diesel Chevy Truck Forum 2 11-10-2005 11:25 AM
