Old 07-20-2007, 05:59 AM   #1
TLing56 is on a distinguished road
Spark Plugs 2000 Chevy
Have 2000 4x4, 4.8. It calls for replacing the plugs 100k. PU a set of AC delco plugs. The part # is different than the one coming out? It now calls for a .040 gap and on the cowl cover it calls for a .060. I check the gap on the plug that came out and it is a .060. Has anybody seen a update on this and why?
TLing56 is offline   Reply With Quote
Old 07-20-2007, 09:26 AM   #2
i would leave it at .060 myself.
i'd rather be hunting
Old 07-22-2007, 11:34 PM   #3
NCroadracer's Avatar
NCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud of
Yes.....The plugs and the gap were updated. Go with the .040,
Subject:Information on New Spark Plugs and Gapping #03-06-04-060A - (02/12/2007)
Models:2004 Buick Rainier
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
2004 Cadillac CTS-V
1997-2004 Chevrolet Corvette
1998-2002 Chevrolet Camaro
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche
2003-2004 Chevrolet Express, TrailBlazer
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon XL
2001-2004 GMC Yukon Denali, Yukon XL Denali
2002-2004 GMC Sierra Denali
2003-2004 GMC Envoy XL
1998-2002 Pontiac Firebird
2004 Pontiac GTO
2003-2004 ****** H2
with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
Attention: Please disregard the Set Gap Per Vehicle Specification statement on the side of an ACDelco® Iridium Spark Plug Box. The statement will be removed from the boxes in the future.
This bulletin is being revised to bring attention to the Set Gap Per Vehicle Specification on the ACDelco® Iridium Spark Plug Boxes. Please discard Corporate Bulletin Number 03-06-04-060 (Section 06 -- Engine/Propulsion System).
• A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed.
• The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01 mm (0.040 in) when the spark plug is made.
Notice: The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
NCroadracer is offline   Reply With Quote
Old 07-31-2007, 10:21 PM   #4
97SierraStepSde's Avatar
97SierraStepSde is on a distinguished road
correct me if Im wrong but this guy here just contradicted himself? he got some douche's "heads up" where the notice at the bottom contradicts everything it said?
Keep it at the manufacturer setting 4 ur block. I just popped some rapid fires in my 4.8. keep it .060. And good luck the plugs on the right side(pass.) of the block are a *****! haha but I got it all done without an extension or anything. And there in there pretty good so dont be affraid 2 go ape **** on em.
Ride Til I Die
97SierraStepSde is offline   Reply With Quote
Old 08-01-2007, 12:51 AM   #5
crabtruck's Avatar
I don't think he contradicted himself the way I read it but I'd go with if you're put in what you took out EXACTLY (no tip change) then the old gap that worked good should still work good.
Old 08-01-2007, 11:10 AM   #6
Maybe if you read his post and understood what he said... You would be a lot less likely to make an *** of yourself.
That "Heads up" as you referred to it, is an actual Technical service bulletin from GMs web site. I'm a 17 year Master Certified GM technician.
He said he has the updated spark plugs... Therefore they need to be gapped @ 0.040 where they should already be as they are "pre-gapped".
Oh .... and good luck with those piece of schit "rapid fire" plugs you just "popped in"..... You are the kind of sheep they are targeting when they make their boolschit claims of superior combustion and multiple spark capabilities.
One problem...... Unless you have a Multiple Spark Discharge ignition system, you're still getting the same spark or less than the OEM plugs produce.
E3 spark plugs gmtech Chevy Truck Forum 5 07-03-2008 06:49 AM
2000 Chevy 4.8 5-speed 2wd Cranking Problems 06BLACKGMC Chevy Truck Forum 2 05-05-2007 04:27 AM
2000 Chevy tranny shifting hard tdbp76 Chevy Truck Forum 5 04-22-2007 09:48 PM
spark plugs vanhal Chevy Truck Forum 7 12-01-2006 05:40 PM
Need help with hesitation with my 2000 Chevy Silverado RSailer Chevy Truck Forum 7 05-08-2006 06:19 PM
