Old 07-20-2007, 07:10 PM   #1
97 silver4 is on a distinguished road
97 chevy blowing fuses, (taillights and dash)
I keep blowing fuses for my dash and tailights, is this a common problem? How can I find the problem? tHANX
97 silver4 is offline   Reply With Quote
Old 07-20-2007, 07:39 PM   #2
Dax
Dax's Avatar
Dax is a splendid one to beholdDax is a splendid one to beholdDax is a splendid one to beholdDax is a splendid one to beholdDax is a splendid one to beholdDax is a splendid one to beholdDax is a splendid one to behold
Trouble shooting 101 would be to check the obvious first...
Are the fuses the correct size/rating
Are the bulbs correct?
If all are correct, it could be wiring.
Dax is offline   Reply With Quote
Old 07-20-2007, 07:52 PM   #3
Super Step is a name known to allSuper Step is a name known to allSuper Step is a name known to allSuper Step is a name known to allSuper Step is a name known to allSuper Step is a name known to all
My first guess would be a ground somewhere. I am not sure how common the problem is for that model truck. Maybe someone else can answer that.
Are the brake lights also blowing fuses, or just the tail and dash lights?
Sure makes you want to think it is in the light switch since the dash lights and running lights both turn on together with the same switch.
Super Step is offline   Reply With Quote
Old 07-21-2007, 04:24 PM   #4
Hayden's Avatar
I had a 94 do the same thing. My wires got pinched (I did alot of offroading) right in the driver side by the rear wheel almost by the bracket that holds the E-brake cable. You might want to do a visual check and then check these wires with a VOM
Old 07-28-2007, 02:29 PM   #5
Austinr98 is on a distinguished road
I had the same problem with my 1995, I found a bare wire leading into my front driverside running light/turn signal. after I taped the bear wire I havent blown another fuse.. remove all your light housings and check the wires for bare rubs..
Austinr98 is offline   Reply With Quote
