Old 09-20-2007, 12:20 AM   #1
ftalge is on a distinguished road
Question Head lights: High-beams work great, low-beams not so much
I have a 2001 Ram 3500 Sport that refuses to show its low beams. All the other lights work (including the high-beams). The dashboard switch checks out fine and I have even replaced the multi-function switch in the steering column. No fuses are blown.
All suggestions are appreciated.
Thanks
ftalge is offline   Reply With Quote
Old 09-20-2007, 08:42 AM   #2
have you cleaned the connections at the lights and applied some dielectric grease? i always check the ceapest things first and light bulbs are at the top of the list.
Old 09-20-2007, 09:19 AM   #3
The above recomendation is very good. start with the easiest things and work from there eliminating the little stuff. since the two bulbs are bad it would appear to be more than coincidence.
Your multi function switch energizes a relay the drives the high / low beams. It is wired as a form "c" contact meaning that the low beans are on a normally closed circuit, and the high beams on a normally open. When the multi function switch is pulled, it energizes the coil in the relay, changing the states of the realy. The low beam becomes open, and the high beam now becomes closed. the problem is either a bad leg in the realy (low beam side) or a bad supply voltage. This supply voltage could be before, or after the relay. This would indicate a bad wire, but testing the relay will give you a direction to continue troubleshooting.
Relays seldom loose one leg, but it is possible. You can verify this by installing another relay known to be good. Your truck is full of them, and they are interchangeable. they just plug in. Simply find one that is the same and install it. They should be marked "OMRON" or "Bosch". If you replace it and it works, you have found the problem, if it does not, you will need to continue on, but this would indicate that the problem is between the relay and the bulb, like a broken wire.
Good luck, electrical is sooooo much fun.
Old 09-20-2007, 05:20 PM   #4
By the way, how are your DRLs?
Old 09-20-2007, 11:40 PM   #5
The "running lights" are working.
Head lights turning off by themselves HickGirl Chevy Truck Forum 4 09-22-2008 09:33 PM
High Intensity Head Light Bulbs? bubbas91lariat Ford Truck Forum 10 08-04-2007 08:44 AM
22R troubles 390FE Toyota Truck Forum 64 12-09-2005 06:43 AM
