Old 12-11-2007, 02:20 PM   #1
rlandryjr is on a distinguished road
1998 Dodge Dakot wont start
Hello everyone, new to this here... so.. hopefully get some good advice
I have the dakota V6 magnum, 5 spd.. was running very rough at idle, shaking the truck.. as of today, it wont start, just keeps cranking, fires with no power and stalls out. I was wondering if it may be something in the throttle bottle, have spark, have PSI of fuel and a good battery. Any suggestions or ideas would be great..
thanks
ron
rlandryjr is offline   Reply With Quote
Old 12-12-2007, 11:23 AM   #2
Thumbs up one step down
I pulled the plugs, they were black as can be, so, replaced them all and started right up, now, 2 simple questions..
How do you adjust air/fuel mixture on the throttle body
How do you adjust the idle as well, seems to run rough at idle.. or does adjusting the air/fuel mixture fix this as well
\thanks to anyone whom can help
Ron
Old 12-12-2007, 01:27 PM   #3
Moderator
being fuel injected you really can't change the air/fuel. That is what the o2 senosrs are for.
The idle you might be able to adjust with an adjustment screw if you have one.
Old 12-12-2007, 04:29 PM   #4
mod-o-tator
on my chevy, my idle is adjusted through a scan tool. i would have it put on a computer and compare the sensor read outs to the factory recommendations. is the problem just at idle?
member map add yourself
Old 12-12-2007, 04:44 PM   #5
yes
it pretty much shakes the truck at idle, I pulled the muffler off today, was shot anyways, im wondering if the catalytic is plugged, no foul smell, but, there is a sensor in the pipe after it, would that be an issueas well?
Old 12-12-2007, 04:58 PM   #6
mod-o-tator
o2 sensor, possible cause right there. do you have any codes, the dash light could be dead, so go to autozone and have them pull codes just to check.
Old 12-14-2007, 12:23 PM   #7
very weird
well, replaced the muffler, it seems to have turned from silver to a goldish color.. very weird from running very hot, im assuming the catalytic is not working properly.. would be my guess.. but, who knows. but, still running rough and backfiring.. It seems to idle low as well, not sure if distributor is properly set.. do I adjust on distributor to get it right.. the plugs seem to be doing fine as well...
1998 dodge dakota v6 3.9
Old 04-14-2008, 11:17 AM   #8
flntlokr is on a distinguished road
Checked your timing?
You might want to check your timing. Could have jumped a cog or two on the chain. I have had it happen on two of those engines.
flntlokr is offline   Reply With Quote
Old 04-14-2008, 04:28 PM   #9
shadow is on a distinguished road
Could Also Be A Bad Destributer Cap If They Get A Crack They Will Miss Fire And Just Stop Running Also
shadow is offline   Reply With Quote
83 gmc wont start joeydeherrera54 GMC Truck Forum 7 11-28-2007 04:30 PM
78 F-250 wont start this morning... milemaker13 Ford Truck Forum 3 03-03-2007 02:09 AM
y wont my truck start right away? eganracing Chevy Truck Forum 6 11-25-2006 05:57 PM
Wont start blue cobra 60 Chevy Truck Forum 3 10-18-2006 10:24 PM
Explorer wont start DesertRacer Ford Truck Forum 0 11-13-2004 04:39 PM
