| Junior Member Join Date: Feb 2008 Location: VA
| Hey all! I am a newbie to this forum although I visit Redpower forum regularly. My '95 dually with auto sudenly lost the ability to up-shift into "high gear" |
| Full Member Join Date: Jan 2008 Location: illinoise
| try putting a new set off batteries in it one may be shorted out i had a powerstroke that wouldnt start and unless i had battery charger and booster pack on it then it would it ended up being the batteries i would try that first its alot cheaper then buyen a new computer |
| Thanks 87S. Both batteries are about a year old but I will load test them tomorrow. I just replaced the alternator as the old one had a cracked housing. I neglected to say that my dually has a Cummins (and a PCM, not an ECU). |
| check your alternator |
| Senior Member Join Date: Jan 2008 Location: L-burg KY
__________________ 2003 Chevy Silverado 2wd short bed 5.3l V8 4L60 |
| Senior Member Join Date: Mar 2007 Location: Currently, I live in Lancaster country, Pennsylvania.
| Isn't the PCM for diesels and the ECU for fuel engines? They run different timming, and different sensors all together, so the computers would be different right?
| That is my understanding (PCM = diesel). New alternator seems to have done the trick. |
| B&M Shift Improver Kit | gmctrucks | GMC Truck Forum | 3 | 01-13-2008 07:58 PM |
| shift indicator off | SilverK96 | Chevy Truck Forum | 11 | 10-06-2007 07:37 AM |
| E4od no shift | ragtagf150 | Ford Truck Forum | 13 | 03-05-2007 09:06 PM |
| Transmission wont shift into 3rd gear,Need help | DEP | Introductions | 1 | 02-10-2007 08:16 PM |
| shift problem | beno | Introductions | 3 | 07-18-2006 08:38 AM |
