Old 02-20-2008, 03:38 PM   #1
90Power4x4 is on a distinguished road
Vibration
I have a 90 PowerRam 4x4.
Just had the all the shaft components re-done,and I just got done putting it back in.
They said they balanced it,but when you shift in to 3rd there's a few seconds of vibration there that wasn't there before.
Does anyone have any ideas of what it could be ?
90Power4x4 is offline   Reply With Quote
Old 02-20-2008, 07:00 PM   #2
Welcome to the site.
Did your new shafts come assembled? Did you undo any of the shafts during assembly? Might just have a shaft that is out of phase and is causing the problem.
Do also make sure that you have the u-joints torqued properly, and installed correctly. Anything that might be off a little, could cause a problem.
Old 02-20-2008, 07:58 PM   #3
Thanks for the welcome Dude I really appreciate it !!!!
I checked everything,and it all seems to be OK .
I had the u-joints put in by a place here in town cuz I dont have the stuff to do it properly .
But I'm honestly lost when you said u-joints torqued properly......What exactly do you mean,cuz I might be missing something?!!!!.
Thanks again
Old 02-21-2008, 07:06 AM   #4
03chevy's Avatar
do you have a 2piece shaft? if so did you replace the center carrier bearing? that could be your problem
Old 02-21-2008, 01:08 PM   #5
I did change the carrier bearing but am still having problems.
It's not doing after shifting gears like I thought,but its doin it starting at about 30mph,and goes till about 38mph,then it smooths out ,it does it even in 4th gear.
Everyone I've talked to here has said the same....Either the shaft is out of balance or I could possibly have a tire going out !!!
BUT...The thing is ,it didn't start this till I put the shaft back in.
I've checked everything to make sure it's centered and tight ....and everything is where it should be,so I don't know........
AAAAAAHHHHHHHHHHHHHHHH!!!!!!!!!!!
Old 02-21-2008, 05:37 PM   #6
Driveline driveshaft troubleshooting
See if this helps a little. Maybe there is something there.
I still believe that your shaft is simply out of phase. Coule be that when you took the shaft apart, it did not go together correctly. Did you mark the shaft at the slip joint and verify that the thing went back together the same way it came apart?
Are all of the u-joints aligned in a row (proper phase)?
Overtightening the u-joint fasteners can also cause a problem, especially if you use u-bolt style fasteners.
Old 02-21-2008, 06:54 PM   #7
Cool I'll look at it!!!!!
The shaft is together the way it came apart.
But I haven't checked the u-joints to see if they are aligned ,and there is a chance that I have the fasteners too tight.
I'll check it out first thing in the morning !!!!
Thanks allot Man.
strange vibration crazyhorse357 Chevy Truck Forum 8 01-22-2008 06:01 PM
Vibration Dartanion Chevy Truck Forum 11 01-13-2008 12:03 AM
vibration 046mag Chevy Truck Forum 5 11-26-2007 11:03 PM
94 Suburban Vibration cookcs Chevy Truck Forum 1 11-01-2006 01:42 PM
Engine Vibration Little Grub Chevy Truck Forum 4 01-27-2006 06:23 PM
