| Junior Member Join Date: Feb 2008 Location: pa
| trans swap New to group with a question. i have a 93 dodge diesel with a bad tranny.I would like to know if you can swap out a tranny froma 93 gas with a 5.9 in it. they are both auto with 4wd. gas truck is a parts truck and it would be a cheap fix if it can be done. if not any other help would be great thanks all |
| just rebuild the tranny, gas tranny won't work |
| the problem is the houseing is cracked and it is no good now |
| Junk yard. take a look, you might get lucky and find one there. Try hitting up the local tranny shops, they may have a trans shell available to them with bad guts, and if your guts are good...... see where I am going? Otherwise look into a rebuilt or remanned one.
| ok thank u i will try junk yard . i see you are from pa 2 we used to live close to york. i guess you are close if you work there. thanks alot |
| Ford manual trans swap | Ford4x4man | Ford Truck Forum | 7 | 01-27-2008 07:25 AM |
| silaverado engine, trans swap | jbtruck | Chevy Truck Forum | 2 | 12-16-2006 07:17 PM |
| trans help | metalbender | Chevy Truck Forum | 0 | 12-09-2006 08:10 AM |
| trans out | nate02 | Nissan Truck Forum | 1 | 05-17-2006 09:15 PM |
| Trans swap | catsass | Chevy Truck Forum | 2 | 02-14-2006 07:19 PM |
