| Dodge Ram 150 1991 Help me please, I have a Dodge Ram 150 1991 4X4 5.2L The engine run for few minutes and quits, I have to wait for a bit then run and quits again it run good for a day than quits the battery is new and also the starter |
| check this stuff out. 1Inspect Fuel Filter Clogged or dirty fuel filter 2Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). 3Inspect Spark Plug Fouled, damaged or broken spark plug(s). 4Inspect Carburetor Float Improperly adjusted/saturated or damaged carburetor float. 6Inspect Timing Cover Stud Kit - PerformanceImproperly adjusted or worn/malfunctioning power valve 7Inspect Choke Pulloff Worn, defective, or faulty choke pulloff(s). 8Inspect Choke Thermostat Stuck or improperly functioning choke thermostat. 9Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. 10Inspect Idle Air Control Valve Damaged, loose, or faulty idle air control valve. 11Inspect Idle Speed Control Actuator Damaged, loose, or faulty idle speed actuator. 12Inspect Idle Stop Solenoid Damaged, loose, or faulty idle stop solenoid. 13Inspect Mass Air Flow Sensor Improperly connected or faulty mass air flow sensor. 14Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit. 15Inspect Electronic Spark Control Module Faulty spark advance system or system components.
| Very helpful 03chevy.... Kudos Welcome to the forum, and if I understand this right, it seems when the truck warms up, it stalls out right? If you keep the accelorator down, can you keep it running? I forget when dodge made the switch, is your motor EFI or carb? If it is a carb, I would think the problem lies in your choke. EFI and I bet the problem is with throttle position. Basically, it sounds like the motor is choking. When it is cold, the air/fuel mixture is a lot stronger then when it is warm. So I bet when it warms up, the proper adjustments are not being made. So to help out bud, let us know if it is EFI or Carb'ed.
| HI it is EFI, Willthe Idle control unit be at fault? |
| That would be my guess. It is getting too much air when it don't need it and not nearly enough when it does. Typical of either a throttle control fault, or even mass air flow. Either way, there is a miscommunication. So yeah, I would start there.
| backfiring before/after change Idle control unit Hi Thank you for reply y'all now I changed th Idle control unit , now it is backfiring and missfiring it runs good only if I press clutch in half way coud the clutch be the problem? Last edited by northerncanada; 05-11-2008 at 04:40 PM. |
| 1991 Toyota truck SR5 v-6 | backwoods91 | Toyota Truck Forum | 6 | 03-31-2008 09:09 PM |
| 1991 Suburban 4X4 | lsphillbilly | Truck Classifieds | 2 | 08-18-2007 08:18 AM |
| 1991 Dodge Dakota 2wd | greasemonkey | Dodge Truck Forum | 2 | 06-24-2007 02:20 PM |
| anybody know about 1991 pickup | jag9177 | Toyota Truck Forum | 0 | 01-10-2007 08:09 PM |
| 1991 abs codes HELP | scootman | Chevy Truck Forum | 1 | 03-13-2006 06:49 PM |
