Old 04-19-2008, 04:26 PM   #1
mjfco is on a distinguished road
power window
I have a 1992 Dakota with power windows, the pass. side will not roll down properly, when it rolls down or up it tips toward the front of the door and gets stuck, I have to right it and then it will go up and or down, I took the the door apart and can not figure out why it is doing it all the window guides seem to be in place and secured, does anyone have a Idea or pictures of the regulator?
Thanks
mjfco is offline   Reply With Quote
Old 04-19-2008, 04:46 PM   #2
Chevy_Finatic79's Avatar
some windows use a plastic clip in side the window track to hold it in place while it operates, but you cant see this clip unless you remove the window. and some use plastic mounting clips on the bottom of the window that push and pull the window one of these could be broken also.
I dont think your regulator is to blame at least not yet remove the window or roll it up and down while you have the door apart and watch how it operates and look for those plastic clips I mentioned earlier. take a flash light and look inside the door at the bottom and see if any thing broken is laying down there.
85' Chevy C-10 Longbox (Rat)
TBI 327 Cu.In./THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 04-21-2008, 07:29 PM   #3
thanks, I found the trouble, there is a clip at the top of the window an it is missing, I'll check with the dealer to see if i can oder one.
1992 Dodge Dakota se cc v8
power window help please teemsta Chevy Truck Forum 8 07-14-2008 07:16 PM
power window repair Charlie390 Dodge Truck Forum 0 04-25-2007 06:59 AM
power window issue JMP2204 Chevy Truck Forum 4 04-01-2007 07:23 PM
power window wont go down atk Chevy Truck Forum 1 03-24-2007 05:53 PM
85 E-150 Power Window and Lock problem clev Ford Truck Forum 1 02-21-2007 06:22 PM
