Old 05-03-2008, 11:13 AM   #1
gerry is on a distinguished road
Head light issue
I recently purchased a 92 dakota 4x4 but can not get the lights to work. I have replaced the light switch, fuses, dimmer switch on the steering column. My dome light will activate if I turn the head light switch. Also the signal lights work but not the park lights, dash lights or head lights. Any ideas what my next step should be.
gerry is offline   Reply With Quote
Old 05-03-2008, 02:13 PM   #2
crabtruck's Avatar
Welcome to the forum gerry.
One of those situations where troubleshooting can save on parts costs.
You replaced fuses and switches, were any of those bad ?
I believe the dome light uses a different fuse than the park&headlights.
Signal/brake/haz lights are on a different circuit.
Check that you have power at the fuse first, if not, check supply.
It actually is good that all lights are failing, means problem is basically
between switch and battery, not the complicated side.
Don't have a diagram for that truck, maybe a bad fusible link ?
Good luck
Old 05-03-2008, 04:55 PM   #3
Banned
has it had any electical mods made to it. aftermarket radio, fog lights, remote starter etc. if you replaced all the switches and nothing worked they i would start with the wiring. you could have a short somewhere or a loose plug. i know a dimmer wire usually goes into the fatory radio and if not caped off right it will give you fuse and wire problems. hope everything works out with it and keep us posted
Old 05-05-2008, 11:02 PM   #4
95Chev is on a distinguished road
Have a 92 3/4 ton that had that problem. It was simply the GROUND WIRE from the battery to the Radiator mount. This is normally about a 10 in long 12ga wire. Had similar grounding problems on late 70's power wagons. recommend checking engine to firewall ground cable and cleaning connections.
95Chev is offline   Reply With Quote
Left Turn Signal/Brake Light issue.. itzmarko1 Chevy Truck Forum 7 01-28-2008 09:52 AM
head light change.. help chevyman_03 Chevy Truck Forum 5 10-30-2007 06:38 AM
High Intensity Head Light Bulbs? bubbas91lariat Ford Truck Forum 10 08-04-2007 08:44 AM
Head Light Trouble claytonfrnk Chevy Truck Forum 5 09-02-2006 01:27 AM
Weird one, headlights and dash light issue Koi_Boy Ford Truck Forum 5 04-24-2006 02:04 PM
