Old 05-22-2008, 09:32 PM   #1
Dearman@MS is on a distinguished road
Question engine??
i have two trucks both have 318 5.2's one is a 1993 ram 150 magnum, the other is an 1999 ram 1500 magnum. the 99' has a bad engine due to bottom end faliure, i want to know what the differences between the 1993 and 1999 vin Y 318. can i simply just swap the upper of the 99' i.e. heads intake exhaust to the 93' short block or is the block different?????? pls help pdt81@yahoo.com
Dearman@MS is offline   Reply With Quote
Old 05-23-2008, 12:17 AM   #2
maverick25204's Avatar
maverick25204 has a spectacular aura aboutmaverick25204 has a spectacular aura aboutmaverick25204 has a spectacular aura about
far as i know thats it just head and intake r diff, might want to make sure cause i am only 80% and thats with a phone a friend
maverick25204 is offline   Reply With Quote
Old 05-23-2008, 06:11 AM   #3
03chevy's Avatar
there is no diff. in the two. now if it was a old 318 then yes that would be anouther story. so whats wrong with using all of the 93? but when you do swap the heads over to the other block, while the heads are off i would install new valve stem seals very easy and cheap to do. autozone has them for 17.00 for the set
Old 05-23-2008, 09:59 AM   #4
heads and intake have diff prot flow and think valves r little bigger on magnum
well sh...
Old 05-23-2008, 10:11 AM   #5
Post thanks guys
I will be making this swap in the shop, the only differ i could think of is the intake to heads these ports must be different. i HOPE the holes in the 93 block line up with the 99 heads. i will use the 99 front ac alt etc. 99 disty so as long as the 99 elect plugs are all used this shouldnt be to bad.... i am hoping.
Old 05-23-2008, 10:17 AM   #6
heads should bolt up dodge didnt realy mess with main designe, they belive in aint broke dont fix it good luck
well sh...
Old 05-26-2008, 09:23 AM   #7
Arrow ?????????????????????????????????????????????
hey guys i just pulled the intake and 1 head off the 93, 318 and guess what! the exhaust intake and headgasket are all the same. the gasket set i am comparing them with is for the 99, 318 so this is what i plan to do simply just use the intake and dist from the 99, on the 93, pls if anyone knows this will work or wont or anything pls reply as i am watching this forum before i go any further........... luck is needed thats all folks.......
Old 05-26-2008, 09:35 AM   #8
Chevy_Finatic79's Avatar
are your "dizzy's" the same length? I would just do a dry fit mock up to make sur all the bolt holes line up and all my clearance's are in specs. and the distributor fit properly and if everything looks like it's supossed to put RTV where it needs to go and bolt it down
85' Chevy C-10 Longbox (Rat)
TBI 327 Cu.In./THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 05-26-2008, 09:42 AM   #9
dissys
the elec. plugs are different this is no prob. to swap dist. its kinda exciting to be doing somthin like this cause everyone around me goes you might me about to ####up! thanks for the reply
Old 05-26-2008, 09:49 AM   #10
what plugs are different? if you are just using the 93' block and the 99' top-end everthing should be exactly the same
Which Engine??? strokin350 Chevy Truck Forum 7 02-27-2008 06:51 PM
Engine misfire detected engine code HELP Airforce wrench Chevy Truck Forum 2 02-21-2008 08:13 PM
What engine? UrbanCowboy Chevy Truck Forum 6 11-30-2006 02:41 PM
engine id great_beer_man Dodge Truck Forum 5 07-13-2006 02:58 PM
Engine ID 74pilot Chevy Truck Forum 3 11-28-2005 09:24 AM
