Old 05-29-2008, 03:44 PM   #1
Nates01Ram is on a distinguished road
Unhappy problem starting
i have a 01 ram 1500 with a 5.2 and when the truck is cold i have to try and crank it 2 or 3 times befor it will fire. if i hit the gas it will start the first or second time what is the problem
Nates01Ram is offline   Reply With Quote
Old 05-30-2008, 08:35 PM   #2
Dearman@MS is on a distinguished road
when have if ever have you replaced the fuel filter, air filter, plugs, wires??
Dearman@MS is offline   Reply With Quote
Old 05-31-2008, 11:38 PM   #3
RandomHero_z71's Avatar
RandomHero_z71 is on a distinguished road
I'm having the same problem with my 02 silverado. My fuel pumps bad. If you haven't changed the filter it can destroy your fuel pump. Theres a trick my friend showed me that will help you, but won't solve your problem. When you get in, turn the key all the way to the on position but don't crank it. You'll probably hear your pump "humming". Wait until it quits humming. Turn it off and then back to the on position and wait for it to hum again. After its done crank it and it should start right up. It's been working for me. I'm waiting for the money to replace my pump, i hear its pretty costly. Somewhere around 300 to 400 bucks. Hope I helped.
2002 Silverado 5.3 vortec.
RandomHero_z71 is offline   Reply With Quote
Old 06-01-2008, 09:51 AM   #4
it not that bad to replace just the pump its self
if all you need is the pump and stainer screen its not tooo costly. the best way to get to the pump is to lift the eh' bed up [you need help] not sure about spanner wrench for chevy might not need one.... g,luck some some dough
Old 06-03-2008, 10:19 PM   #5
Yeah i heard from everyone that's replaced theirs that liftin the bed is the best way to go.
Old 06-05-2008, 05:07 PM   #6
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
idle air control (iac) motor is sticking, when you open throttle plates your giving engine air.
jimbo543 is offline   Reply With Quote
Hard starting problem. mdj21 Toyota Truck Forum 13 05-16-2008 06:41 AM
Starting Problem njk53 Chevy Truck Forum 2 02-05-2008 05:39 PM
99 S10 2.2l PU Starting problem JMP99S10 Chevy Truck Forum 3 05-06-2007 04:28 PM
99 Chevy starting problem chevyz71 Chevy Truck Forum 2 01-24-2006 07:27 AM
Problem starting Keith23 Chevy Truck Forum 3 03-10-2005 09:43 PM
