| the 99' ram with the 93' bottom end is built and put in. but no crank got gas and fire but no vroom???????????????????????? 1999 ram 1500 5.2 PLEAASEEE HELP!!!!!!!!!!!! i have to drive it to s.carolina in like 2 dayss |
| was there a crank sensor on the 99' you for got to put on the 93?
__________________ "She's gonna Freak when she see's my wheels" 85' Chevy C-10 Longbox (Rat) TBI 327 Cu.In./THM350 90' Chevy Suburban 4x4 TBI 350 Cu.In./700R4 http://www.truckforum.org/forums/truck-pictures-176.htm |
| fire fuel time all correct everything hooked up right runs but rough check engine light is on will run code tomorrow. would the temp sensor keep it from running if so how about running well? |
| firing order?
| checked it once checked it twice... you know how the saying goes... will give it another look with fresh head tomorrow. any info on temp sensor? what about the disty being elec. and timing not adjustable externally only so many things in world can go wrong RIGHT? |
| I'm a chevy guy so I'm not to familar with dodge motors but on the chevy you disconnect a base timing wire then set your timing and when you hook it back up the computer takes over from there. like I said tho I dont know if dogde has that wire or not.
| runs great THANKS FOR THE HELP YOU GUYS |
| oh yea it was the crank pos sensor it wwas bent straighted it and vroom on dodge it is in the rear |
| transmission ????????????????? urgent | mikerike | Chevy Truck Forum | 2 | 11-14-2005 01:38 PM |
