| 1998 Dakota Shifting problem I just bought a 1998 dakota sport pickup.When I start it up and take off driving it will not shift out of low gear for about a half mile or so. After it does shift it is fine, stop at light,stop sign,what ever it will shift fine,UNTIL I turn it off then the process starts agian.It will run fine untill it is shut off.Any ideas? Thanks |
| Senior Member Join Date: Jun 2006 Location: Hampton, Va
| yeah i got an idea.... It's a Dodge... also, is it automatic? or manual? cause if its manual the i can def. tell u what the problem is. lol |
| check the solenoid connector on the transmission if its automatic make sure it is all the way on the solenoid and there is no dirt or mud on the contacts |
| buddy had the same problem. his was the pressure sensor inside the valve body. $450 at the shop. $50 for the part. drop the pan, drop the valvebody, replace.. buy new tools or alot of beer with the money saved.
__________________ 1996 Z71 white shortbox tinted 350 30 over cats and X pipe Alumhds ported 210 cc runners 62 cc chambers 2" int 1.550" ex crane lift; 580/580 duration; 216/222 4L60E w/shiftkit |
| 1988 chev truck overdrive shifting problem | pwilson | Chevy Truck Forum | 2 | 06-01-2008 06:39 PM |
| shifting problem | allthrotle | Chevy Truck Forum | 5 | 01-23-2008 12:34 PM |
| 95 dodge shifting and overdrive problem | bsolis | Dodge Truck Forum | 0 | 03-24-2007 04:01 PM |
| Automatic tranny problem,trouble shifting | DEP | Dodge Truck Forum | 3 | 03-01-2007 01:19 PM |
| 99 Silverado shifting problem | 04HEMIRAM | Chevy Truck Forum | 8 | 02-15-2007 08:09 AM |
