Dodge Truck Forum - Chat about dodge trucks, dodge accessories, & more. |
#1 (permalink) |
02 sensor
i have a 98 dodge ram and was just wondering if there are any symptoms when a o2 sensor is gone my truck sort of bogs when going slow or just pressing lightly on the gas peddle while driving sometimes coughs out the breather but if you step on it works fine also got the 02 sensor code left bank sensor 2 so is that another problem too
#2 (permalink) |
Well, welcome to the site...
If the ECU threw the O2 sensor code, then I would think it is a fair bet they need to be replaced. However, remember that when the O2 fails, it is usually a symtom of a larger problem, wither EGR is allowing it to run rich, or MAP is forcing it to run lean, or extended moisture in the fuel etc. Replace the O2's and see if that solves it for ya.
Lets get some mud on the tires...eh?!?!? ![]() ![]() ![]() OWN: 1998 Chevy Blazer ls 4x4 4.3l Vortec V6 ![]() 1998 Mazda B3000 SE 4WD 3.0L V6 3" lift ![]() 31x10.50 Liberator A/T's |
#4 (permalink) |
I have the same problem going on with my 04, they should be almost the same layout. Bank 1 Sensor 1 is the first sensor on the driver side before the cat. the bank 1 sensor 2 is the first one after the cat. But mine was throwing wrong codes and come to find out the whole cat is not holding oxygen and i gotta replace cat and all the sensors.... hope yours is really just the sensor.
#5 (permalink) |
Moderator
do you know what the code number was? knowing whether it is a * lean or rich condition will help solve the problem (* low circuit voltage or high circuit voltage. the o2 sensor code could also be for lazy sensor ( slow response).
junior is correct in saying that an o2 sensor code is usually a sign of a bigger problem. Last edited by mudseeker; 07-06-2008 at 05:47 PM. |
| o2 sensor | jdfenske | Dodge Truck Forum | 2 | 05-25-2008 07:45 PM |
| MAF Sensor | mxer201 | Mazda Truck Forum | 5 | 11-30-2007 08:03 AM |
| o2 sensor | bud-4-u | GMC Truck Forum | 2 | 01-12-2007 07:31 AM |
| 97 S-10 cat/O2 sensor | SKINNYME | Chevy Truck Forum | 1 | 08-08-2006 09:32 AM |
| Bad sensor? | truckpower | Chevy Truck Forum | 3 | 06-28-2006 05:52 PM |
