Old 07-05-2008, 01:45 PM   #1
jvon is on a distinguished road
1999 Dodge diesel starts and dies
New fuel pump and filter, the problem is getting worst, before it would run for a while then it acted like I turned the key off. Now it starts and dies right away. Had a fuel pump go out a few years ago and kill my injector pump, this does not seam to be the same. Thank for any help.
jvon is offline   Reply With Quote
Old 07-05-2008, 07:58 PM   #2
stumpuller454's Avatar
stumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud of
air leak before lift pump, is possible anyways seen it lots on the diesels, good to rule out anyways
Old 09-09-2008, 06:20 PM   #3
thomasnchy is on a distinguished road
It wasnt a Dodge, but the last Powerstroke I worked on did the same thing.. acted like someone reached over and turned the key off. It was the crankshaft position sensor.
thomasnchy is offline   Reply With Quote
Old 09-09-2008, 07:09 PM   #4
Moderator
I would check for air leak like stump said and then check the TPS. TPS is a common problem on the cummins.
1999 6.5 turbo diesel problems 1-tonsrule Chevy Truck Forum 2 06-02-2008 08:13 AM
Starts, dies and then won't re-start dogbone Ford Truck Forum 22 04-09-2008 01:33 PM
1999 F-250 7.3 Turbo Diesel engine oil, filter, etc info. Kawboy Ford Truck Forum 2 12-26-2006 09:33 AM
Dodge 1500-1999 TERC_TX Dodge Truck Forum 1 07-06-2006 10:24 PM
92 starts dies and won't start again Geoffp GMC Truck Forum 4 09-19-2005 09:55 PM
