Old 08-23-2008, 07:40 PM   #1
lost in wyoming is on a distinguished road
wont start when cold
86 dodge with a 360 wont start when its cold. give it some starter fluid it fires right up. starts right up when its hot. changed pump filter eccelerator pump any thoughts
lost in wyoming is offline   Reply With Quote
Old 08-24-2008, 01:46 PM   #2
leolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud of
Does it have a temp sensor? sounds like a sensor is shutting down the fuel flow. Or is it carb with a butterfly not closing all the way?
Old 08-24-2008, 02:49 PM   #3
no temp sensor. Edelbrock carb manual pump. choke closes all the way
Old 08-24-2008, 08:50 PM   #4
ok I assume you mean manuel fuel pump, sounds like the pump is losing prime when it sits for a while , check the line from the tank to the pump. instead of either try reg gas.....less chance of a problem later
Old 08-27-2008, 08:15 PM   #5
we tryed that. he put all new gas hoses on it
Old 08-27-2008, 08:56 PM   #6
Lariat's Avatar
Lariat will become famous soon enoughLariat will become famous soon enough
Do you run your engine without a air cleaner/filter? Did you add the carburator on at a later date? Try getting it started and then before you turn off your engine each time give it a little gas then shut it down immediately. Lubricate the choke and de-pit/clean the carb intake and butterfly. Replace the inline fuel filter as well. Make sure it isn't backwards.
What is between the manifold and the carb?
Lariat is offline   Reply With Quote
Old 08-29-2008, 08:20 PM   #7
its a freinds truck. he has a air cleaner on it. the carb was on the truck when he got it .he put a new filter on it. the truck sat for a few years even tryed fresh gas. now he knows why his father inlaw gave him this thing.
Old 08-29-2008, 09:21 PM   #8
Lariat's Avatar
Sounds like a seasonal truck - stays cold when its cold out and gets heated up for the summer weather. Send it to So. California or Florida. lol
Old 09-04-2008, 08:47 AM   #9
When you start it cold do you use the old carb procedure........step on the gas 2 times then stay off and turn the key?
Old 09-15-2008, 08:32 PM   #10
if he pumps it 3times then half throttle it starts right up. but he has to give it gas when he cranks it
Diesel won't start when cold dkburrell Ford Truck Forum 16 07-20-2007 11:32 AM
7.3L hard start when cold wmiller Ford Truck Forum 9 06-02-2007 07:31 PM
2002 1500 wont start in the cold bigdog101197 Dodge Truck Forum 1 02-05-2007 04:22 PM
98 S-10 Cold start problems 1935ford Chevy Truck Forum 2 01-17-2007 01:58 PM
Clacking on Cold Start mattymax Nissan Truck Forum 6 01-02-2007 06:29 PM
