Old 08-31-2008, 11:57 AM   #1
6coupe4 is on a distinguished road
1996 ram pcm bad ????
How do you know if your PCM is BAD? I've made a comment on kwulkat's thread, but I then noticed he has a 1998. I'm getting no spark of fuel.
6coupe4 is offline   Reply With Quote
Old 09-01-2008, 08:48 PM   #2
Lariat's Avatar
Lariat will become famous soon enoughLariat will become famous soon enough
Is it a diesel? If so follow these guidelines:
Stored diagnostic codes can be displayed by turning the "ignition" key ON-OFF-ON-OFF-ON Within three seconds. The fault codes will flash on the "CHECK ENGINE" light located at about the 8:00 position on the tachometer face. This procedure works for the 94-96 12 Valve engines. The 97-98 12 valve and the ISB all require the DRB diagnostic tool to obtain trouble codes.
As an example, a 23 code would be indicated by FLASH, FLASH, PAUSE, FLASH, FLASH, FLASH. Multiple codes may be displayed, and the sequence always ends with 55. Green codes will light the CHECK ENGINE lamp when the engine is running. CODE MEANS
11 No crank signal detected during cranking
12 Battery was disconnected within the last 50 key-on cycles (Resets after 50)
15 No vehicle speed/distance signal while driving
23 Intake manifold air temp sensor voltage too high or too low
24 Throttle position sensor voltage too high or too low (automatic only)
33 An open or shorted condition detected in the AC clutch relay circuit
34 Open or short in the Speed control solenoid circuits or
Speed control switch voltage too high or too low
37 Open or short in the Torque converter clutch solenoid CKT circuit or
Voltage high or low at transmission Temperature sensor
41 An open or shorted condition detected in the alternator field control circuit
42 An open or shorted condition detected in the Auto Shutdown Relay circuit
44 An open or shorted condition detected in the engine coolant temp sensor circuit or
A problem exists in the PCM battery temperature / voltage circuit
45 An open or shorted condition detected in the overdrive solenoid circuit
46 Battery charging system voltage too high
47 Battery charging system voltage too low
53 Internal PCM circuitry or communication failure
55 End of sequence. Last code sent to indicate the end of the codes.
62 SPI miles not being updated as vehicle travels
Every second is a second chance. Live it up!
Lariat is offline   Reply With Quote
Old 09-02-2008, 10:22 AM   #3
Moderator
bradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud of
lariat, i do not believe it is a diesel if he is getting no spark or fuel. coupe, someone here while back has mentioned something about a problem similar to this originating from the dizzy. without spark, the injectors will not spray. maybe this individual will come on and shed some light on it.
Old 09-02-2008, 12:14 PM   #4
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
no fuel/spark, crank sensor bad
jimbo543 is offline   Reply With Quote
Old 09-02-2008, 06:15 PM   #5
Sorry, It's a 5.2 L gas.
1996 Z71 mack222 Chevy Truck Forum 2 04-30-2008 08:27 PM
1996 B2300 Slacker Mazda Truck Forum 3 02-11-2008 07:48 AM
1996 GMC For Sale EaTmYtAiLpIpEs GMC Truck Forum 0 06-21-2007 12:37 PM
1996 gmc jimmy CHUCKYD444 Introductions 0 12-02-2006 05:17 PM
1996 s10 stepside scott8950 Chevy Truck Forum 0 06-09-2005 07:06 PM
