| My 360 is misfiring ? The plugs, wires,distributor,and rotor have been changed. I'm getting codes 300,303,305. cylinders 3&5 Last edited by steve d; 09-05-2008 at 11:55 PM. Reason: forgot part of the sentence |
| perform compression test first, if good clean/flush injectors, replace intake and plenum gaskets and bolts. |
| what did the plugs, wires, and cap look like when you changed them?? did you have the codes cleared when you put all this stuff on there and then try driving it again?? |
| Full Member Join Date: Sep 2008
| I've done this for a while, lots of tune ups and basic maintenance. I just put new plugs and wires on my 1996 1500 w/a 360and had the 5-7 wires backwards. That distributor is way back there and it was all "by feel", and the 5-7 on the rotor is side-by-side and closest to the block. I ended up wiggling each wire from the rotor and having a co-worker watch where it went, and sure enough I had them backwards. |
| '99 Dodge 5.9 TPS | jlsavoy | Dodge Truck Forum | 1 | 05-27-2008 06:46 AM |
| dodge hemi | lucky | Dodge Truck Forum | 0 | 11-14-2007 01:30 PM |
| AC Dodge Ram | RUSTY55 | Dodge Truck Forum | 1 | 06-15-2007 07:25 AM |
| 05 4x4 dodge ram | Nicks 05 ram | Dodge Truck Forum | 1 | 12-19-2006 07:48 AM |
| old dodge ? | 64longstep | Dodge Truck Forum | 4 | 09-08-2006 10:57 PM |
