| 1999 dodge cummins acceleration I have a 1999 2500 cummins runs good then i get a check engine light,then it has a hard time to get to 50mphits like it has no throttle,my thought is my throttle position sensor as my vp44 is only about 1 yr old and at the same time i replaced my stock lift pump with the FASS pump,im hoping its as simple as changing out my tps.thanks in advance for answers |
| It sounds like its in default (diesels do that) you need to scan it and go from there
| a faulty tps is usually going to cause high idle and late shifting. is this relating to the p02 something another code you mentioned in another thread?? something having to do with high voltage for turbo?? |
| yes I scanned it today Po238 turbo boost senson or(MAP sensor) ordered one today.Will give it a try. thanks to all |
| let us know how it turns out. |
| My turbo boost sensor arrived this morning,about 30 minute change out,and my truck is running like a champ,so code P0238 is turbo boost sensor (MAP sensor) ![]() |
| good deal. happy to hear you are back running |
| Junior Member Join Date: Feb 2009
| Vp-44 bosch HELP I need a BOSCH VP-44 INJECTOR PUMP NEW EXCHANGE OR A GOOD USED , IT,S A 1999 , 24 VALVE, AUTOMATIC |
| might get better results by starting your own thread in the corresponding topic. |
| 1999 dodge ram 3500 | foxdodgeman1998 | Dodge Truck Forum | 7 | 09-09-2008 12:00 PM |
| 99 dodge 2500 cummins | jlsavoy | Dodge Truck Forum | 2 | 05-11-2008 03:27 PM |
| Dodge Cummins Parts | DPDIESEL | Truck Classifieds | 6 | 02-16-2007 10:20 PM |
| Dodge 1500-1999 | TERC_TX | Dodge Truck Forum | 1 | 07-06-2006 10:24 PM |
| 1999 Dodge Durango SLT 4x4 review (Carsurvey.org) | trucknews | Truck News (headlines) | 0 | 02-03-2005 07:30 AM |
