Old 10-20-2008, 06:49 PM   #1
mazdatrucker is on a distinguished road
Smile 1967 D100 wont shift
I have a 1967 D100 that has been stored for about 3 months. Everything ran and drove when i stored it. Now trying to drive it and it cranks and runs but just grinds when i try to put it in gear. Will go in gear without the engine running. Is the clutch stuck? There is hyd fluid in the resivour.
Clutch feels firm & solid. Thanks for your help!!
mazdatrucker is offline   Reply With Quote
Old 10-21-2008, 07:54 PM   #2
clutch might need to be adjusted.
Old 10-21-2008, 07:59 PM   #3
FaselZ71's Avatar
I had this problem in my 85 blazer! I had fluid in the resevoir but you couldn't put it into any gear and reverse just sounded terrible!! You stored you vehical for a while and you got air in you slave cylinder line take off you fluid cap and bleed your clutch by pumping the clutch slowly until all the bubbles are out try to put it in gear if it works drive it alittle ways and then try to bleed it again until all the bubbles are and that should fix your problem! Good luck hope this helps!
Transmission wont shift into 3rd gear,Need help DEP Introductions 3 11-11-2009 04:17 PM
MY 1995 F150 wont shift!!!!!HELPPPPPP rapter Ford Truck Forum 1 10-08-2008 11:09 PM
94 3500 diesel manual with chevron tow wont shift got stuck on Rear dspabout Chevy Truck Forum 4 08-23-2008 11:44 AM
94 chevy 3500 w/ 265,000 miles wont shift DaveF Chevy Truck Forum 8 08-16-2008 06:14 PM
AutoTransmission wont shift Randyram Dodge Truck Forum 6 02-04-2008 06:16 PM
