| Junior Member Join Date: Nov 2008
| 1988 dodge D150 differential My 88 D150 has a limited slip differential. When everything is cold no problems. After the truck is driven on the freeway more than a few miles when you come to a stop it shakes and sounds like something in grabbing. I have changed the diff fluid, front calipers and breaks and ujoints. Any ideas? The more that the drive train heats up the worse it gets. |
| have you looked into the rear breaks yet?? |
| Yes and no. I have looked at them for wear and damaged parts and see any problems but not as a cause of this issue. Also forgot to mention that the rear end is out of a 1992 with anti lock breaks. |
| I have since had an avid off road guy I work with look at the rear end and his opinion is that it is not that bad. He thinks it is in the transmission. I have been wondering about that me self. It is almost like there is a rear bearing or bushing at the end of the transmission that when every thing gets wormed up has too much play and allows the drive shaft to move around at the transmission end. Does this sound reasonable? I am thinking of having the transmission rebuilt. |
| Does your truck have a 2 piece drive shaft? |
| is your truck a 2 wheel drive that has a carrier bearing in the middle of your driveline? Ive had them go bad and do something similar to that |
| Just for kicks as it starts to happen manually downshift it and see if it stops
| It dose not have a piece drive shaft. My problems happenes after it is in 1st gear, right berore the truck comes to a stop. |
| Sorry, it does not have a 2 piece drive shaft. |
| okay.... I wrote that response before I comprehended what your problems were... so yeah |
| Drive shaft or differential ??? | aretevince | Mazda Truck Forum | 13 | 10-21-2008 04:19 PM |
| Differential gear ratios | 2nd65 | Chevy Truck Forum | 1 | 04-28-2008 02:27 PM |
| Front Differential Leak | Charlieb | GMC Truck Forum | 5 | 04-09-2008 11:45 AM |
| Differential ratio | riverasierra | GMC Truck Forum | 2 | 02-19-2007 04:58 PM |
| GMC sierra. 4x4 differential question | will4831 | GMC Truck Forum | 12 | 02-22-2006 04:17 PM |
