Old 11-06-2008, 06:41 PM   #1
coltstrader is on a distinguished road
Smile 6 for 8 engine swap
I have gotten a lot of different information, but would like opinions on swapping my blown 318 in a 1977 3/4 ton automatic trans 4x4 for a rebuilt slant six. The exchange book says no, junk yard says yes If I use the six torque converter. Supposedly the 318 is internally balanced and the six is external, and if I use the six converter, I am ok, otherwise most everything bolts up, any thoughts, thanks ss.
coltstrader is offline   Reply With Quote
Old 11-06-2008, 07:15 PM   #2
stumpuller454's Avatar
i`m not 100% but most manufacturers use the flexplate when balencing an external balenced engine, although i can see it possible to have weights put on the converter, it would have to be bolted on to the flexplate in the correct correlation, otherwise it may shake like crazy! Is the slant 6 of the same year/make? Maybe they were just talking about the flexplate not the converter?
P.S. WELCOME ABOARD!
Old 11-06-2008, 10:39 PM   #3
Banned
yeah i think they are talking about te flex plate not the converter... if it was the converter then they couldnt sell oem ones by themselves they would have to sell a hole motor with it... lol... i have never heard of such a thing so i wuld look into your sources a little bit more.. i say they are totally wrong.. they may be talking about bolt holes from the flex plate to the converter not lining up... or the splines not matching the trannys one... im sure there are conversions around or someone that has done it... anything is achievable now adays
Old 11-07-2008, 05:07 AM   #4
You both may be right, surely someone has pulled this off, will continue to check, thanks so much for the quick replies, I really appreciate the help from forums like this, they have saved me several times, as I can't afford 80 bucks an hour.
Old 02-17-2009, 04:09 PM   #5
terrywerm's Avatar
terrywerm is on a distinguished road
You don't balance the engine with the torque converter or with the flywheel/flexplate. Those parts are balanced independently so that when mounted on an engine they will not disrupt the existing balance of the assembly.
Terry
Real trucks rattle!
'01.5 Dodge Ram, QC, SB, 4x4, 5.9 CTD, 5 Spd
'99 Dutchmen 30' 5th wheel
'87 Jeep YJ, 6 cyl, 5 spd (project)
terrywerm is offline   Reply With Quote
Old 02-17-2009, 04:12 PM   #6
terry i see you are a newbe, check dates on posts, if they are more than a month old an inactive there is no sense posting
Engine swap AndyinCt. Chevy Truck Forum 5 07-01-2008 08:28 PM
92 into 89 Engine swap cc2058 GMC Truck Forum 5 06-19-2008 02:48 PM
engine swap LUIS Introductions 2 03-04-2007 01:56 PM
Engine Swap help cody_321 Chevy Truck Forum 17 02-23-2007 12:19 PM
Engine swap ? 72farmtruck Chevy Truck Forum 3 11-10-2005 09:57 PM
