| Junior Member Join Date: Nov 2008
| 2003 Ram 1500 Wiper Arm Alignment I have a 2003 Dodge Ram 1500 (Hemi) during a recent snow I started my truck to warm it up and not realizing it until my wipers popped from the ice and snow that I had left the wiper switch on (my stupidity). The wiper motor seems to work fine through all cycles but the wipers are off 45 degrees from where they should be when the switch is turned off. I’ve pulled off the plastic cowl from under the hood. I have access to all the guts to the wiper assembly. If I could figure out the original alignment of the wiper linkage crank arm that’s bolted to the wiper motor shaft and the relationship of the key way slot in the wiper posts. I’ve not been to successful finding the right location. Is there anybody out there that might have done this before? Thanks John |
| never done it but it will be very much trial and error. that arm that connects to the motor, does it have a channel that uses a bolt you can move up and down?? |
| i've done it to my chevy once. the drivers side was hitting my moon visor. i just took of the cowl like you did and loosened the bolt on the linkage to adjust it.
| The wife did the same thing to our 98 Ram. Wipers wouldn't park down. Something got out of wack in the wiper motor mechanism. Had to replace it. Auto zone has them. |
| Tags |
| wipers |
| 2003 GMC Sierra 1500, Radio Problems | Ninja_Lawn_Guy | GMC Truck Forum | 4 | 07-21-2008 08:55 AM |
| AC intermittant-2003 1500 | rickw | Chevy Truck Forum | 12 | 06-13-2008 01:35 PM |
| axle swap alignment | Hayden | Chevy Truck Forum | 9 | 09-08-2007 11:02 PM |
| 2003 dodge ram 1500 sb,cc | marrsbarak | Dodge Truck Forum | 0 | 12-19-2006 12:45 PM |
| alignment | yaigottagmc | GMC Truck Forum | 2 | 10-30-2006 07:12 PM |
