| Junior Member Join Date: Oct 2008
| Losing coolant I have a 2002 dodge 1500. I am losing coolant from the plastic reservoir. Cannot see a visible leak anywhere and there does not appear to be any water in the oil, which would indicate a blown head gasket. However, there was a small crack at the neck of the reservoir where the cap screwed on, but it was repaired. Any suggestions on where it could be going? Thanks, Lisa |
| the engine could be burning up the coolant before it has a chance to get to the oil.
__________________ i'd rather be hunting Last edited by mudseeker; 12-05-2008 at 08:17 PM. Reason: wrong word |
| what do you mean by losing it from the resevoir?? i am assuming that you have not verified that the resevoir is the culprit?? you might have a connection that is starting to leak a little or something leaking on top of the manifold that is evaporating the evidence. |
| Can you smell burning anti-freeze? DO you notice any water at the tailpipe? Some water in the exhaust is normal, but you should be able to smell burning coolant if there is a problem. How much anti-freeze are you losing? |
| Senior Member Join Date: Jul 2008 Location: tallahassee, fl
| headgasket seeping into a cylinder?
__________________ 2004 gmc 1500 cc 4x4 |
| Yes, you can smell it. And yes, there is water coming out of the tailpipe and excessive smoke, which just started happening. I am losing all of the anti-freeze in reservoir in about 2 days time. On start ups the smoking is worse. After driving for approx. 15 minutes it reduces. |
| Also, I have put gas treatment in my tank, would that cause excessive moisture, causing it to smoke?? |
| if you have that smell, you are burning it somewhere wether it be on top of the manifold or there at the heads. if you are still smoking after it warms up, i would lean toward a head gasket or intake gasket. |
| | #9 | |
| | #10 | |
not possible. the radiator cap opens at 8 to 14 psi and releases into the overflow tank. this allows for expansion of the coolant from cold to hot. | |
| losing coolant :( | keithr0005005 | Chevy Truck Forum | 24 | 04-16-2009 08:11 PM |
| Oil in my coolant | dhashigu | Chevy Truck Forum | 15 | 08-07-2007 02:29 PM |
| Diesel losing Power | GMC Smiley | Chevy Truck Forum | 2 | 02-15-2007 06:15 PM |
| Diesel Losing power | GMC Smiley | GMC Truck Forum | 0 | 02-14-2007 06:02 PM |
| When Life Is a Losing Streak, Remember the Red Sox (New York Times) | trucknews | Truck News (headlines) | 0 | 01-02-2005 11:30 PM |
