| 2002 dodge 3500 v10 not idling My truck will not stay running. Its okay going down the road and as soon as i come to a stop it dies. When I start it in the morning i have to keep my foot on the gas to keep it running. Please help. |
| here is a check list that you can do. 1Inspect Fuel Filter Clogged or dirty fuel filter 2Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). 3Inspect Spark Plug Fouled, damaged or broken spark plug(s). 4Inspect Carburetor Float Improperly adjusted/saturated or damaged carburetor float. 6Inspect Timing Cover Stud Kit - PerformanceImproperly adjusted or worn/malfunctioning power valve 7Inspect Choke Pulloff Worn, defective, or faulty choke pulloff(s). 8Inspect Choke Thermostat Stuck or improperly functioning choke thermostat. 9Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. 10Inspect Idle Air Control Valve Damaged, loose, or faulty idle air control valve. 11Inspect Idle Speed Control Actuator Damaged, loose, or faulty idle speed actuator. 12Inspect Idle Stop Solenoid Damaged, loose, or faulty idle stop solenoid. 13Inspect Mass Air Flow Sensor Improperly connected or faulty mass air flow sensor. 14Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit. 15Inspect Electronic Spark Control Module Faulty spark advance system or system components.
| i would say start with the IAC. one that is malfunctioning has all your symptoms. are you getting an SEL light?? |
| sounds like that or maybe a vac leak EGR, split hose, hose off, broken plastic do-dad
| leo, i have been lookin for a part number for the uhhh, plastic do-dad. can you shoot that number over my way?? |
| do you want the one for the front or rear of the engine?
| the engine?? i thought you were talking about the tranny. i still think that the problem is going to be the IAC. but you could have it right as a vac leak. |
| If he was tinkering he might have knocked something off, remember when everthing was hose and metal fittings for vac
| Dodge Ram 3500 eng.swapout | bullseyecat | Dodge Truck Forum | 1 | 02-17-2009 04:14 PM |
| Need Opinions on a 1998 Dodge Ram 3500 | ibkg | Dodge Truck Forum | 2 | 10-03-2008 05:53 AM |
| 1999 dodge ram 3500 | foxdodgeman1998 | Dodge Truck Forum | 7 | 09-09-2008 12:00 PM |
| 97 Dodge 3500 Dually | watkins7871 | Introductions | 0 | 11-28-2006 06:53 PM |
| What are your experiences with the 2002-2005 Dodge Ram Trucks? | Info Seeker | Dodge Truck Forum | 2 | 01-14-2006 01:23 AM |
