| The o2 sensor hasn't fixed it.... could my caty be another cause |
| what year is the truck agian? did the CEL go off or have you cleared it? did any other codes pop up?
| What are you trying to fix?????????????
| is this still the same problem with the shutter? |
| 98 dodge ram 1500 and no the light didnt go off. it said the catalyst was below efficiency |
| well, without seeing the data stream from the scan tool, i would say your cat is restricting your exhaust too much. that's what happens when you got a bad o2 sensor, causing your engine to dump too much fuel into your system. i would suggest you find someone who can do a good scan on the truck(may have more bad sensors), along with replacing the cat.
| problem fixed |
| Glad it's fixed! So what was the final solution? and how did you find it?
| i'm guessing the cat.
| Leaks Fixed! | 76silverado | Chevy Truck Forum | 10 | 11-29-2008 08:37 PM |
| exhaust fixed but something not right | bigz | Chevy Truck Forum | 13 | 11-02-2008 04:22 PM |
| ABS light but no codes*fixed* | Moostang | Dodge Truck Forum | 11 | 07-07-2008 06:46 PM |
| 02 sensor | bazil649 | Dodge Truck Forum | 5 | 07-06-2008 06:43 PM |
| Bad sensor? | truckpower | Chevy Truck Forum | 3 | 06-28-2006 06:52 PM |
