Old 12-23-2008, 06:51 AM   #11
If you do the compression check and it is low, squirt some oil in the cyl and see if it comes up(that would mean rings)
however, A lot of the manufactures seem to have trouble with plentum gaskets, How did the previous owner make th determination?
Old 12-26-2008, 08:24 PM   #12
daville_pits's Avatar
daville_pits will become famous soon enough
he took it to his shop and i guy said that was the problem from what i understand....dont know if any test were ran or not
daville_pits is offline   Reply With Quote
Old 12-27-2008, 12:58 PM   #13
well have at it then, make sure all the parts are clean before reassembly, and use a torque wrench. let us know how you make out
Old 12-28-2008, 10:56 AM   #14
ran compression test on #8 was 40 and # 6 was 170 so i think there is a piston problem on #8 is there anything i can do to bring it back up without pullin the motor.......let me know asap!!!
Old 12-28-2008, 11:15 AM   #15
stumpuller454's Avatar
This...
Originally Posted by leolkfrm View Post
If is low, squirt some oil in the cyl and see if it(compression) comes up(that would mean rings)
if compression is not restored it may point to a burned vavle.
Old 12-28-2008, 11:16 AM   #16
you may have a burnt valve. did you try squirting some oil in the cylinder to see if the compression bumped up?
i'd rather be hunting
Old 12-28-2008, 11:19 AM   #17
ok result on squirting oil it went up maybe to 50 55 at most
Old 12-28-2008, 11:23 AM   #18
time to pull the head and intake and replace the gaskets along with checking out the cylinder walls and valves.
Old 12-28-2008, 11:25 AM   #19
so is it the piston rings on that cylinder or something else... would a bad plenum gasket or intake gasket cause this
Old 12-28-2008, 11:46 AM   #20
any response??
Tags
cracked head, no compression
where do these plugs go brad4eva Chevy Truck Forum 6 07-14-2008 05:47 PM
1996 K1500 plug fouling Get Bent Chevy Truck Forum 6 05-14-2008 06:26 PM
1992 5.7 TBI #1 Spark plug fouling cplnorton Chevy Truck Forum 7 11-09-2007 08:37 PM
98 tahoe fouling #3 and #5 plugs chandler Chevy Truck Forum 4 03-17-2007 10:08 PM
Plugs chevy-eater Ford Truck Forum 15 10-05-2005 05:20 PM
