Old 12-21-2008, 05:04 PM   #1
daville_pits's Avatar
daville_pits will become famous soon enough
Fouling plugs out??
I just bought a 1998 dodge ram 1500. They guy i bought it from said that about every 600 miles u have to change the plugs becasue oil is fouling the plug.i drove it from Minnesota to kansas which is about 700 miles and i havent notice anything. the check engine light was on when i bought it i check it and it was #8 cylinder misfire so i thinking with 7 fouling out its making 8 foul to but i havent notices any oil burning but i have only drove it one day so i just askin for ideas on oil being on the plugs casue obiviously it burnin enough to foul the plug. any ideas
daville_pits is offline   Reply With Quote
Old 12-21-2008, 05:08 PM   #2
see error's Avatar
see error has a spectacular aura aboutsee error has a spectacular aura about
welcome
how many miles on the truck.
2004 gmc 1500 cc 4x4
see error is offline   Reply With Quote
Old 12-21-2008, 05:51 PM   #3
bad valve seals? worn piston rings?
do a compression check and you'll find your culprit.
i'd rather be hunting
Old 12-21-2008, 06:29 PM   #4
change the oil and filter, put lucas additive in it, and drive it, see what happens. Autolight plugs are good for oil burners, they don't foul as fast
Old 12-21-2008, 07:40 PM   #5
stumpuller454's Avatar
PCV valve could be bad... beleive it or not. could cause excessive oil to be pushed down the vavle stems or past the rings. cheap fix
Old 12-22-2008, 03:45 AM   #6
YES stumpuller is big times correct I have seen it happen on a dodge car. Might give it a good tune up with quality parts meaning not from Auto Zone.
Old 12-22-2008, 04:02 PM   #7
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
Intake manifold plenum gasket. Very very big/common problem with 318/360
jimbo543 is offline   Reply With Quote
Old 12-22-2008, 08:26 PM   #8
ok the truck has so 109,000 miles runs good but you have to replace the plug ever 500 miles or so..... the guy i bought said it was the intake gasket but how do u know for sure dont wanna be a parts thrower lol so any ideas are good thanks
Old 12-22-2008, 08:28 PM   #9
and what should the compression be??? roughly
Old 12-22-2008, 08:40 PM   #10
well, my compression is around 170 with one cylinder at 115. as long as they are all around the same, you should be ok. you could also rent the tool at autozone and do a leak down test too.
Tags
cracked head, no compression
where do these plugs go brad4eva Chevy Truck Forum 6 07-14-2008 05:47 PM
1996 K1500 plug fouling Get Bent Chevy Truck Forum 6 05-14-2008 06:26 PM
1992 5.7 TBI #1 Spark plug fouling cplnorton Chevy Truck Forum 7 11-09-2007 08:37 PM
98 tahoe fouling #3 and #5 plugs chandler Chevy Truck Forum 4 03-17-2007 10:08 PM
Plugs chevy-eater Ford Truck Forum 15 10-05-2005 05:20 PM
